Got the parts, ready to start construction.
Page 1 of 1 [8 Posts]
lynes
PostPosted: Sat Feb 11, 2006 9:30 pm    Post subject: Got the parts, ready to start construction. Reply with quote  Mark this post and the followings unread
At last I have all the parts together for the Sound Lab, ready to start building. While I was waiting I designed my own front panel.........
Any comments.
Bill
My Sound Lab front panel design, more pics to follow as I progress with the build.
 Filesize:  78.52 KB
 Viewed:  122 Time(s)
dnny
PostPosted: Sun Feb 12, 2006 3:35 am    Post subject: Reply with quote  Mark this post and the followings unread
nice!
IMHO in the VCF section the "signal in" connectors shoudl be 1/4 jacks and the "voltage in" banana jacks.
www.koelse.org
flickr: cable porn group
lynes
PostPosted: Sun Feb 12, 2006 8:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks man,
I'm not a musician and I just want to make some weird noises and effects with the sound lab. I wanted to fit everything inside a relatively small box hence the smaller jacks.
I'm gonna stick with the 1/8 jacks and use adapters. The Jacks are Tip jacks made by Johnson components and the pots are all 16mm.
More pix to follow as I start to build.
Bill
Pehr
PostPosted: Mon Feb 13, 2006 4:44 am    Post subject: Reply with quote  Mark this post and the followings unread
dnny wrote:
nice!
Why not just 1/4" jacks? I like them better...
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
dnny
PostPosted: Mon Feb 13, 2006 8:10 am    Post subject: Reply with quote  Mark this post and the followings unread
there is a old topic jacks vs. banana and there is a discussion about bananas and jacks.
but jacks 1/4 or 1/8 are better for routing external audio signal in because the grounds connect on the same plug - if you use bananas and lets say wan´t to connect your CD player to VCF you need to have a extra banana for the ground - you have it right way on the VCA module so why not also on the VCF?.
a good example is Damion Romero's panel
it has also 8 ground points for bananas. for connecting whit external devices.
but everything depends on how you want to use your SL.
take a look at these topics
Signal Input Question
Audio In?
there is a .pch2 file that emulates Sound Lab.
whit this and G2 demo you can explore SL patching possibilities.
Emulation of the SoundLab analog synth. Basic building blocks, knobs, and MIDI only.
www.koelse.org
lynes
PostPosted: Mon Feb 13, 2006 9:16 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm sticking with the 1/8th jacks for audio signals, and the smaller tip jacks for voltages. This way I can fit more into less space.
I finished the board yesterday, next comes drilling the holes on the front panel of the case. Im using a Hammond sloping front box purchased from Allied Elec.......
Model # 1456KH3WHCWW
http://www.hammondmfg.com/pdf/1456KH3.pdf
http://www.hammondmfg.com/dwg16.htm
I will post some pics as I progress the case.
Bill
dnny
PostPosted: Mon Feb 13, 2006 11:44 am    Post subject: Reply with quote  Mark this post and the followings unread
oh Man! tip jacks and specially tip plugs are so cute - also the Hammond slope case... - i´m curious to see the patchable micro SL.
daniel
www.koelse.org
lynes
PostPosted: Mon Feb 13, 2006 11:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I will try and take a few pics as I drill out the case and assemble all the pots, switches and jacks etc.
Maybe I will start a new thread entitlted 'Mini Sound Lab Construction Photo's' or something simular.
Bill
Niio2
