RND Pattern module
Page 1 of 1 [8 Posts]
mother misty
G2 patch files: 130
PostPosted: Tue Feb 21, 2006 1:01 am    Post subject: RND Pattern module Reply with quote  Mark this post and the followings unread
Hi all,
I'm a bit confused about the rnd pattern module, and to be more specific, the step/prob mod. input.
No matter what I plug in into this input it doesn't seem to react.
I attached a patch with some examples.
first example.
upper modules (blue & green) are identical, just the blue circuit is connected with a mod source (LFO)
the green one not. Like you can see the result of the blue & green modules are identical, how does this comes?
second example (red modules, turn on mixer)
A random pattern generator clocked at audio rate.
Again the mod input is connected with an LFO, no matter what rate or polarity you select from the LFO there's no effect.
How comes the mod input doens't seem to react to anything I plug into it, am i missing something here.... ?
RNDPAT_TEST.PCH2
 Filename:  RNDPAT_TEST.PCH2
 Filesize:  1.55 KB
 Downloaded:  641 Time(s)
Audio files: 116
G2 patch files: 317
PostPosted: Tue Feb 21, 2006 1:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Apparently you are the first one to have ever tried :-)
I think this can be moved to the bug forum, or do you want to make a new topic for that ?
mother misty
G2 patch files: 130
PostPosted: Wed Feb 22, 2006 12:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for checking jan!
Apparently you are the first one to have ever tried Smile
I don't think a new topic is necessary, just move it.
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Wed Feb 22, 2006 1:47 am    Post subject: Reply with quote  Mark this post and the followings unread
On another note, I didn't realise you could use the rnd pattern module as a wavetable osc with thousands of preset waveforms Shocked
Hopefully Clavia will address this issue in a future update so it becomes a wavetable osc with a modulatable spectrum Shocked
Audio files: 116
G2 patch files: 317
PostPosted: Wed Feb 22, 2006 11:36 am    Post subject: Reply with quote  Mark this post and the followings unread
mother misty wrote:
just move it.
ok
mother misty
G2 patch files: 130
PostPosted: Thu Feb 23, 2006 6:14 am    Post subject: Reply with quote  Mark this post and the followings unread
I've e-mailed this to clavia aswell...
cebec
G2 patch files: 31
PostPosted: Thu Feb 23, 2006 8:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah, that's how i discovered this bug, too... i e-mailed clavia about it, once, and then forgot about it.
jamos
G2 patch files: 35
PostPosted: Sun Feb 26, 2006 3:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ditto, I just tried it and it doesn't work. When using the pattern module as a waveshaper, truning the Step/prob knob lightens or darkens the sound, but it can't be modulated. Bummer.
