  bingsatellites Mostly Ambient
Cable thickness?
Page 1 of 1 [3 Posts]
Sprak
PostPosted: Thu Feb 23, 2006 1:26 am    Post subject: Cable thickness? Reply with quote  Mark this post and the followings unread
Hey,
does the thickness of the cable matter much in the construction of the soundlab? I'm currently using 0,08 mm² cable (don't know how much that is in non-metrics, but it's definitely much thinner than otcx's fine cable work recently posted here). Do I risk interference between cables? I'm banding them together 6 and 6 too (for the oscillators for example).
http://www.covox.net
Audio files: 51
PostPosted: Thu Feb 23, 2006 3:34 am    Post subject: Reply with quote  Mark this post and the followings unread
No, it should be fine.
The only limiting factor really is how difficult it is to work with. So you don't want it too thick. The signal levels in the SL are pretty high so there's no risk of interference really. If you want you can screen some of the output lines back to the mixer or maybe a bit further, but there's really no need to.
We would lose our friends.
So,.........
Sprak
PostPosted: Thu Feb 23, 2006 5:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Aah, glad to hear that! Now I don't have to resolder every cable Smile Thanks.
Niio2
