Question about a preset
Page 1 of 1 [2 Posts]
nickelodeus
PostPosted: Thu Mar 02, 2006 5:27 am    Post subject: Question about a preset Reply with quote  Mark this post and the followings unread
Hey Guys!
Hope you're all well.....was just flicking through some presets....bank1, which i normally don't look at since there's a lot of unusable arp/seqs in there!
Preset 068 i think is a sound called harmonic pad. It seems to use the arp to move the sound but when u turn the arp off, the movement is mostly still there. I tried fiddling with the LFO rates, but doesn't seem to make much difference.....my knowledge of LFO/S&H isn't that great. Can anyone tell me how this movement is being created and why turning the LFO rates seems to make little difference to this main movement?
I really like the evolving/phasing feel of this sound but would like to try and turn off the movement
cheers
nic
sunny pedaal
Audio files: 12
PostPosted: Fri Mar 03, 2006 4:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
you have to check the modulations used.
quick way is to press view for the different parts like osc/ prefilter/ filter/ postfilter and then press mod. then you'll see which modulator is on and other info and you can try them on/off.
also handy is to press the black ribbon button and go for grid and control- route to find out if any modulator is controled by any other controler.
take a piece of paper and pen and with the info provided with the steps above it should be able to tackle the problem.
greetings, sunny
