  bingsatellites Mostly Ambient
LoopHead-Changing Sequencer loop length bug[and soln v2]
Page 1 of 1 [16 Posts]
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Thu Mar 16, 2006 2:21 pm    Post subject: LoopHead-Changing Sequencer loop length bug[and soln v2]
Subject description: Don't you hate it when you change the loop length and the seqeunce IMMEDIATELY jumps to step 1?
OK, a topic more akin to my focus... Wink
The NM1 sequencers worked correctly and change the loop at the next time the sequencer reset (on the downbeat).
I am hopeful Clavia is going to fix this, but in the interm, a cheap solution. It's cool too, cuz you can set more than one loop point and then turn the shortest one off and it will jump to the next shortest one. Neat for live situations.
This is a simple little trick for the beginners and anyone else. Let me know if you have any comments or questions.
/Dasz
All those blinky lights
[x][o][_][x][x][_][x][x][_][_][_][_][x][_][x][_]
 Filesize:  52.87 KB
 Viewed:  5475 Time(s)
LoopHead_DZ.pch2
 Filename:  LoopHead_DZ.pch2
 Filesize:  2.61 KB
 Downloaded:  656 Time(s)
http://www.clavia.se/misc/users/daszgarncarz.htm
http://haagenlive.blogspot.com/
PostPosted: Thu Mar 16, 2006 5:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
I suppose "worked correctly" is/was subjective, but I fully agree with you on this. It is difficult for live improvisation when the beat gets unsyncronized, unintentionally, undoubtedly!!!
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Thu Mar 16, 2006 5:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Subjective? I would say not. It's common practise for any groove box I have worked with. And consistent with NM1.
Totally, the G2 is supposed to be more Live oriented than Papa Nord (NM1). Especially after you read the marketing line which tells us why it is so much better than NM1
http://clavia.com/products/nordmodular/index.htm
These little glitches get in the way (esp since one cannot group the quick solution into a subpatch) Sad
/Dasz
ps.: I have a sentimental attachment to the Colorado Avalanche hockey team-- esp "Burnaby" Joe Sakic (http://www.coloradoavalanche.com, and Mr. Steve Moore for suffering such an underhanded blow thanks to Todd PooToosey (Bertuzzi) http://canucks.com/theteam/roster.asp?sectionID=23&id=20#career )
selvmarcus
G2 patch files: 39
PostPosted: Thu Mar 16, 2006 8:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
It´s strange these things didn´t get fixed during so many years.
Is it really the missing menpower at clavia?
Another example: Why is it I cannot define or use some
keyboard shortcuts for module type insertion?
Would be so much faster than to go through the menus all the time.
Why no multiples module or any place to put one of my patchcords somewhere while exchanging two of them? Always have to go again... Sad
Sorry, OT here.
Still a great product and I am allover very happy with it.
Fun and research for years to come. Good buy.
Marcus
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Thu Mar 16, 2006 8:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Isn't that enough for now? Remeber Clavia is a Small Company! Not many people doing s/w or h/w stuff (they are not Roland!!!)
/Dasz
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Thu Mar 16, 2006 8:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
I learned a lot during NAMM '06 about really small companies -- they seem to be doing all the cool stuff, funny isn't it? The big guys just copy the small guys.
/Dasz
Unfed
G2 patch files: 11
PostPosted: Fri Mar 17, 2006 12:29 am    Post subject: Reply with quote  Mark this post and the followings unread
thank you for coming up with this, Dasz! i loved the fact that you could change the number of steps on the fly, but was quickly disappointed to find that it didn't work quite right. thus, wasn't able to make use of it really at all. this should be a great help.
could you explain why this is? (maybe it'll make sense to me when i actually play around with it...)
PostPosted: Fri Mar 17, 2006 12:48 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't think it's that subjective. The sequencers come with a reset input so it's much easier to have a extra reset patched in manually then it is to prevent it from resetting.
That being said; the G2 has the lookup table sequencers and those enable you to define your own "correct behaviour". With those you can for example have the "last step" parameter outside of the sequencer module and only update that parameter once in -say- every 8 bars together with a global reset of all sequencers, that would make it all ableton style. In the NM you can do the same if you'd like to but it'd work differently.
To me the bigest thing is defining for yourself what "correct" is for any given situation, once you have that you can probably build it regardless of what the modules do per default.
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Fri Mar 17, 2006 11:50 am    Post subject: Reply with quote  Mark this post and the followings unread
good point about the ctrl sequencer, Kassen.
I used a solution like it as well, but the circut was bulkier than the little reset step in the event sequencer.
unfed, I was stating that it is too bad we cannot create subpatches (like in reaktor). This way, this little circuit could have been turned into a "module".
/Dasz
Audio files: 116
G2 patch files: 317
PostPosted: Fri Mar 17, 2006 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
With this little modification the patch will work for a sequencer length of one as well, it costs about .3% extra in cycles.
a patch example, see it's thread
 Filesize:  37.03 KB
 Viewed:  5358 Time(s)
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Mon Mar 20, 2006 4:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Jan,
In my patch solution, of course you realize that if the current step is above the loop length step you just changed to, your sequence will play until step 16. One can think of this as a bug / feature. Rolling Eyes
I like the x0x school of thinking -- bug or feature?
/Dasz
Audio files: 116
G2 patch files: 317
PostPosted: Mon Mar 20, 2006 5:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Guess not actually .. I've no clue as to what you are talking about ... did I overlook something, if so please be more specific ?
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Tue Mar 21, 2006 10:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, if the current step was 5 and the loop reset was at step 12. then changing the loop length to 4, would not reset the sequence, since we were on step 5 and this is past the loop reset step. You'd expect the sequencer to check for loop point when it jumps to new step.
This is why the voltage/ctrl sequencer is better for the task. But for quick fix, this solution is good.
My posted ideas may not be perfect, nor are they indended to be. They are a start for others, which why I am happy Jan modded this patch!
/Dasz
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Tue Mar 21, 2006 11:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's a different approach using a ctrl seq.
/Dasz
LoopHead2_DZ.pch2
updated. THis version uses a ctrl sequencer. and a loop point knob.
 Filename:  LoopHead2_DZ.pch2
 Filesize:  1.92 KB
 Downloaded:  603 Time(s)
3phase
G2 patch files: 138
PostPosted: Wed Mar 22, 2006 12:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
You are probably aware of that..but actually its the best to dont use the loop mode at all...than you cheaply enjoy the luxery of any looplength up to 128 steps...
I rarely use one bar loops..as soon you start doing your own loop circuit ist not a problem anymore
loophead_3p_134-.pch2
 Filename:  loophead_3p_134-.pch2
 Filesize:  2.64 KB
 Downloaded:  594 Time(s)
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Wed Mar 22, 2006 2:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh yeah, use the clock div is a great solution.
It's cool I tried some patches here, cuz they solved a problem I had in a different type of patch.
/Dasz
