 Forum index » Clavia Nord Modular » Wish List
More inter slot busses please.
Page 2 of 2 [33 Posts]
Goto page: Previous 1, 2
Do we want more inter slot busses?
No thanks, 4 is enough.
12%
 12%  [ 3 ]
Hmmm... I'd like some more audio busses please.
4%
 4%  [ 1 ]
Those control signal busses sound like a good idea... yes please!
25%
 25%  [ 6 ]
I could do with more audio AND new control signal busses!
58%
 58%  [ 14 ]
Total Votes : 24
Audio files: 116
G2 patch files: 317
PostPosted: Sat Mar 11, 2006 3:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
selvmarcus wrote:
May be the crossfaders as DIY sample and hold
behave not so well, sometimes. Will try this.
One could exchange the other ones for valswitches and use the
"standard" logic inverter as clock, as they didn´t work
together with my level converter clock for some reason.
Oh, come to think of it .. I did have problems with the cross fader in the delay line multiplexer as well & got 'm out ... sory, could have remebered that earlier :-)
selvmarcus
G2 patch files: 39
PostPosted: Sat Mar 11, 2006 3:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ups, sorry, yes....
the four channels version had some "extra circuit" which
defeated some of the good intentions... Confused
The sample-and-hold at the receiver was not needed.
In fact we are using full resolution and need every sample
at this stage.
Marcus
4audio-ovr-bus1+.prf2
 Filename:  4audio-ovr-bus1+.prf2
 Filesize:  4.92 KB
 Downloaded:  568 Time(s)
Audio files: 116
G2 patch files: 317
PostPosted: Sat Mar 11, 2006 3:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Much better, it works !
I'm going to make a building block item for the long delays, may I invite you Marcus to do so for the multiplexers ? I'll put some linking in the new and old threads then.
Things are geting out of bounds a bit for this thread maybe.
Edit : also see : http://electro-music.com/forum/post-7076.html
selvmarcus
G2 patch files: 39
PostPosted: Sun Mar 12, 2006 8:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I´m working on it...
I figured out inter-slot sync *is* needed sometimes.
You´ve been right, of course.
This is the solution I came up with so far.
The other perf is the corrected 8 channels diy multiplexer
for the interested (without the extra sync yet).
Should this go to Experimental Forum for now?
Feel free to move it.
Marcus
8voices-to-fx.prf2
Experimental perf sending signals of 8 voices to fx area using multiplexing ( 4 pairs ).
All clocks are synced by sending a click on bus1 at patch activation.
 Filename:  8voices-to-fx.prf2
 Filesize:  4.09 KB
 Downloaded:  554 Time(s)
8audio-ovr-bus1+.prf2
DIY 8 channel audiorate mux/demux (12 kHz sampling for each channel)
 Filename:  8audio-ovr-bus1+.prf2
 Filesize:  7.01 KB
 Downloaded:  505 Time(s)
Audio files: 116
G2 patch files: 317
PostPosted: Sun Mar 12, 2006 8:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
I thought it would be a nice one for the building blocks section. I'm feeling lazy though right now (hell its about time I went to bed Smile ), so when you still have some energy left ... hint ... hint Wink
Too bad the asynchroneous syncing, so to speak, dont work. I'll check the patches later, tomorrow or so.
Audio files: 116
G2 patch files: 317
PostPosted: Mon Mar 13, 2006 4:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, had a look at the patches.
The topmost indeed has some channel mixup/bleeding.
Thought the 2nd one was not working ... but having a better lookI found a bad audio cable :-(
The sync click is pretty smart ! And as it's only once at patch startup it could be sent even over the same bus line as used for an audio signal (just make it !LOUD!).
Nice as well to see the voice allocation at work.
3phase
G2 patch files: 138
PostPosted: Mon Mar 13, 2006 11:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
wow...One at first non patch related discussion leading to breakthru new tricks for the G2 *applause* Smile..thats the way i like it...
thanx...
selvmarcus
G2 patch files: 39
PostPosted: Thu Mar 16, 2006 8:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
See also
http://electro-music.com/forum/topic-10638.html
for some building blocks giving you more busses of audio or control
by using multiplexing.
Marcus
Niio2
