Please verify this bug
Page 1 of 1 [20 Posts]
Tim Kleinert
Audio files: 6
G2 patch files: 201
PostPosted: Wed Mar 22, 2006 10:06 am    Post subject:  Please verify this bug
Subject description: notorious delay line weirdness possibly detected!
As some of you might know, the delay lines have been bothering me since I bought my G2s two years ago. Evil or Very Mad
There was always something strange going on with them when using them for high accuracy stuff like physical modelling.
For a long time I believed that the 16 bit dynamic depth was the culprit, but somehow that didn't scan right. The artefacts I was repeatedly confronted with sounded very different from the kind of typical harmonic distortions you get from low dynamic resolution. And anyhow, 16 bits would still be good enough. Proof is the CombfFilter module, which is based on the same 16 bit memory, but doesn't produce those artefacts and sounds much much better for physical modelling applications.
But using the comb filter module all the time is restrictive in its own right, as it uses considerable more DSP and only offers logarithmic delay length response (very convenient for some purposes, less so for others).
I'm currently working on a patch similar to AAS string studio. It was initially based on comb filters, but I started breaking it down to delays (for DSP/polyphony reasons) and ran into those same old gremlins again. Evil or Very Mad But I think I got them this time.
Please try out the attached patch. If you get what I got, then you should hear a strange cyclic rustling coming out of delay line 2. But please notice that no audio is running into delay line 2! Shocked There is, however, audio running into delay line 1 (whose output isn't going anywhere). Turn off audio into delay 1, and delay 2 becomes silent too.
Or, turn off constant modulation value going into the time mod input of delay 2, and it also becomes silent.
I suspect that something funky is going on with the readout pointers, causing delay 2 to sometimes fetch a few samples of what is in delay 1.
Could you please verify this.
thanks,
tim
Bugreport 220506.pch2
 Filename:  Bugreport 220506.pch2
 Filesize:  1.35 KB
 Downloaded:  724 Time(s)
beer
Audio files: 107
PostPosted: Wed Mar 22, 2006 10:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Yep, I think you have certainly identified a problem. My G2X V1.4 does exactly what you say it does.
I moved this to the Bugs forum... Idea
Tim Kleinert
Audio files: 6
G2 patch files: 201
PostPosted: Wed Mar 22, 2006 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, even the demo version does it. Shocked
So, good that you moved it to the bugs section, where it belongs now.
Ha! This is a personal victory for me. Twisted Evil ! FINALLY, I found what was going on all the time! Ah, the relief.
But -will Clavia ever fix it? Confused
beer
cebec
G2 patch files: 31
PostPosted: Wed Mar 22, 2006 10:17 am    Post subject: Reply with quote  Mark this post and the followings unread
i can confirm it on the Demo, too...
i would e-mail Clavia, and link them to this thread, perhaps...
Tim Kleinert
Audio files: 6
G2 patch files: 201
PostPosted: Wed Mar 22, 2006 10:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, at least I can go on with the patching now, knowing that it's not my fault.
I'll have to live with the artefacts though, until Clavia comes up with a fix. Rolling Eyes
beer
Chet
G2 patch files: 35
PostPosted: Wed Mar 22, 2006 11:06 am    Post subject:   Reply with quote  Mark this post and the followings unread
That's excellent detective work, Tim. Clavia should be able to track it down pretty easily now.
PostPosted: Wed Mar 22, 2006 11:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Getting the same sound on the demo version here too.
Actually I quite like this sound- it reminds me of the noises/ feeling that you get when you stand under major electricity grid overhead powerlines!!
There are many quirks in hardware modulars and some would even argue that these quirks add character.
This has always been my complaint with the digital stuff- that it's too perfect.
Oh well- well spotted anyway Smile
ACHTUNG!
Audio files: 107
PostPosted: Wed Mar 22, 2006 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, this is perfect. Perfectly awful.
3phase
G2 patch files: 138
PostPosted: Wed Mar 22, 2006 12:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
In case somebody informs them... You cant expect them to scan the forum regulary..
3phase
G2 patch files: 138
PostPosted: Wed Mar 22, 2006 12:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Its not perfect..its just simple...
Tim Kleinert
Audio files: 6
G2 patch files: 201
PostPosted: Wed Mar 22, 2006 12:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't need the sound of "electricity grid overhead powerlines" in my waveguides, thank you. Laughing
beer
PostPosted: Wed Mar 22, 2006 1:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Laughing
ACHTUNG!
Audio files: 116
G2 patch files: 317
PostPosted: Wed Mar 22, 2006 2:29 pm    Post subject: Re: Please verify this bug
Something got a bit over-optimized I guess ... when you throw in another unconnected delay the sound will stop (well, just to be sure, on the modified version that I have now) throwing in other modules or removing ones changes the character of the sound sometimes.
There have in the past been examples of this effect involving other (non delay) modules (that got solved).
Good work of you to pinpoint this with such a simple patch !
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Wed Mar 22, 2006 2:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice find. Could also be some memory which is not cleared fully Wink
/Dasz
http://www.clavia.se/misc/users/daszgarncarz.htm
http://haagenlive.blogspot.com/
Audio files: 218
G2 patch files: 93
PostPosted: Thu Mar 23, 2006 5:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah! Good work spotting that. I've run into this before as well, with a feedback loop over a delay that started living all by itself without any input when the delay length attenuator was modified by a MIDI send module.
/Stefan
dorremifasol
Audio files: 6
G2 patch files: 47
PostPosted: Wed Nov 15, 2006 4:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't know if this the same bug but I find it extremely disappointing. I really love Tim's NL3 unison patch but I can't use it because there is some background noise going on when the delays are modulated. This is a really big bug! It shortens the (quality) sound possibilities by a largue amount, as the modulated delays are now useless, in the quality sense.
I'm posting this patch wich shows clearly the background noise I'm refering to. Sorry if this topic has been discussed before.
By the way, this is my first patch Smile sorry, a bad start.
delay noise.pch2
weird delay noise
 Filename:  delay noise.pch2
 Filesize:  1.83 KB
 Downloaded:  708 Time(s)
Albert
Axiom Crux
PostPosted: Sun Oct 18, 2009 3:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
So can someone at clavia fix this already!!!!!!!!!!!!!!!!!!!!!!
drapdap
PostPosted: Thu Oct 22, 2009 5:49 am    Post subject: Reply with quote  Mark this post and the followings unread
i don't think so, since they went a bit of church organ, you know...
they miseralby failed with the second run of expansion boards too.
seems to me we are boiling in our soup and Nord couldn't care less.
it's not that it bugfixes didn't happen, nor the dsp board, but the way they
don't communicate at all, at least they'd mail or tell somebody like Jan that
sorry folks it's not going to happen, or something, just say something...
For me it's not the G2 who died but nord keyboards.
Flames off...
róbert
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Fri Oct 23, 2009 4:59 am    Post subject: Reply with quote  Mark this post and the followings unread
that bug has been bothering me as well. it took me some time in the beginning before i really noticed it. But it seems to produce unwanted noise and sounds low quality. and this should still be fixed as i think clavia (nordkeyboards) is a high quality product range..
shall we just collect Signatures from everyone and send the mail to the nords chief. and just bother them a bit untill they cant go around it.
Tim Kleinert
Audio files: 6
G2 patch files: 201
PostPosted: Fri Oct 23, 2009 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
This bug compromises the chorus module (makes it unusable in a professional recording session if mixed upfront), as well as DIY chorus/delay stuff.
Interestingly though, I've not run into the bug when using the delay module for elastic audio stuff (which I'm very relieved about).
But in terms of audio fidelity, it's the worst bug on the G2 IMO.
It's definetely got to do with the delay module memory allocation and/or the readout pointers. Probably just some wrong scaling or offsetting. In other words: just sloppy coding. Laughing According to Rob, the delay modules are still in alpha state, and never got finalised at all. A high quality product. Confused Laughing
All in all, it's obvious that Clavia overtaxed themselves when developing the G2. Because, when you look at it, the G2 system was a herculean task. And when they saw the low sales figures rolling in, and the resulting lack of ROI, they probably had to put a lid on it immediately. I can understand that. It's a business after all.
What I don't understand is the lack of communication. They could at least have gone public, saying "OK guys, we are very sorry, but we simply cannot afford to finalise it and deliver the remaining features we had publicly announced. (remember those physical models? Wink ) There will be no more updates, no bugfixes, nothing. Take it as it is or leave it." In that manner, people could have decided if they still wanted to go along with it, or not (I probably would have anyway). Then at least nobody would have felt let down.
I still believe the G2 could have been a top seller if Clavia understood something about marketing. But how can you know about these things if you refuse to communicate with users, actual and prospective? Wink The omission of preset documentation especially was the downfall of the G2. Not everybody can read a signal flow, and without understanding what's going on, a preset isn't really useful. Hell, even I never understood how most of the presets operated or what the assigned parameters (often not even named) actually did. I never bothered with them, not once.
I think that this downright refusal of communication and exchange with the user base is something a company only can afford if they release their products totally complete, finalised and bug-free. Otherwise I find it quite a disrespectful, if not even loathsome way to do business.
But it doesn't matter anymore. The products Clavia produces nowadays are simple and foolproof, so no communication with users is necessary. Turn on, select a piano patch, done. Even I can do that. Laughing Which is fine. I think the NordStage and all the other newer Clavia products are really fantastic.
The arena of the gigging keyboardist is one of the last resorts for hardware manufacturers, so I can totally understand Clavia focusing on that field entirely. I think it's a good strategy, and their products are successful because they really are good. I therefore doubt we will ever see another synth product from Clavia. The competition against software is just to big. In the pre-DAW-age, a NordLead or a NordRack was almost a must in the studio. All that demand has vanished. And most gigging keyboardists are not synthesists, but preset users (which I don't mean disrespectfully). The NordWave was Clavia's attempt to fuse the NordLead synth concept with the rompler-preset concept. The result was so-so. The lack of multisampling, keyboard splitting, multichannel-FX, only 18 (Shocked) voices etc., meant that it couldn't hold a candle against true rompler preset machines. The NordLead fans on the other hand missed the lack of 4 slots, individual outputs, filter FM, only 3 morph groups etc. -all in all a step back from the NL3.
beer
JuneSolstice2013
