hjnewcomb
Posted: Thu Mar 30, 2006 4:00 pm Post subject:
Sequencer for performing Live Subject description: help me please |
hey,
I'm in a band or couple http://www.myspace.com/thetwoenglishteadrinkers
and we are doing electro music and have been asked to perform live by several people.
the problem is we have about 6 instruments between us.
What do you think the easiest way to do this live would be .
play a few instruments and leave the rest running through a laptop.
or get like a hardware sequencer i put some tracks on that.
I have a EMac that we use to produce the music on and an Ibook that we could use for performing live i think it has OSx on but tis my dads so i shall check.
any wise comments would be nicely excepted thanks again.
Henry. |
Joined: Jan 31, 2003 Posts: 17337 Location: Allentown, PA
Audio files: 107
Posted: Thu Mar 30, 2006 4:10 pm Post subject:
I listened to your tracks. Sounds like your arangements are pretty tight. Good stuff...
If you have an OSX machine, that might be the best way to go. I think it's best not to buy stuff unless you really know you need it.
What are you using now to produce your music? You must have some kind of sequencer to produce these mixes, eh? Why not continue to use it?
At any rate, playing vocals and a live instrument or two to backing tracks on the laptop will probably be the simplest way to get going. Lots of people are doing this. Using something like Abelton Live would be nice because you can easilly jump around in your arrangements - repeat solos - choruses - bridges - etc - with the push of a button. _________________ --Howard
my music and other stuff |
hjnewcomb
Posted: Thu Mar 30, 2006 11:25 pm Post subject:
thanks |
thanks,
but shame to say i am using garageband..
i will try and get ableton thanks sounds good.
i need to go now i have an interview for an art course..
thanks again
H |
Audio files: 107
Posted: Fri Mar 31, 2006 6:17 am Post subject:
You could, of course, use GarageBand for your backing tracks quite effectively. Why not go with what you have and know? If there is something you want it to do that is beyond its capabilities, then find a tool that does what you need. _________________ --Howard
dasz
Joined: Oct 16, 2004 Posts: 1624 Location: vancouver, canada
Audio files: 29
G2 patch files: 56
Posted: Sun Apr 23, 2006 1:58 pm Post subject:
There is Ableton Live. It does a lot of good stuff, but is mainly controlled by one person (the one with the mouse).
If you chose to go other ways i/e h/w, then the way to go is the Yamaha RS7000 h/w groove sequencer. It's pattern based with x0x editing mixing and muting (so 2 people can control it at once), with sampling and it is flexible, you can import MID files and it has 2 midi outs to control external gear -- and most importantly, it takes less power (energy) from this earth than a laptop. It has more blinky lights than a laptop.
It HAS a learning curve. Not too bad, but it is not a Nord G2
/Dasz _________________ http://www.clavia.se/misc/users/daszgarncarz.htm
http://haagenlive.blogspot.com/ |
hjnewcomb
Posted: Tue Apr 25, 2006 4:03 am Post subject:
cheers.. but. |
cheers
looks like a wiked machine.
only i need to be controlling it and im in a bit of money problemos atm so it'll have to wait jst buying a electronic drum kit full size 8 pads secoind hand wih sequencer on board..
so that should sort me out at present
thank alot tho guys
Henry. |
Machiavelli
Posted: Wed May 03, 2006 3:32 pm Post subject:
Miditemp Multistation MSX: Built for live performance Subject description: Using sequencers in live performance situations |
Take a look at the Miditemp Multistation MSX:
http://www.synthax.com/midimsx.html
I've been doing live-performance with sequencers for years. Laptops are great but VERY fragile on the road. I've been using this machine for a while now. It's awesome! I use it in live-performance as my midi master controller, playing back midi files that control my sound modules, digital mixers, light controllers, and the internal soundfont sample player; 8 audio tracks with special efx, etc., and the song-lyrics (karaoke style) appear on LCD video monitors for my lead-singer. It's very sturdy and stable (never had a crash yet) and the touch-screen remote control makes it very easy to operate.
1U rackmountable Midi sequencer / Midi file player, Midi file recorder, Digital audio player, Digital audio recorder, MP3 player, JPEG player, Dual soundfont synthesizer, Midi matrix 8 in / 8 out (master controller), Midi processor, with touch screen remote control (2nd optional), Lyrics on remote control screen or TV/monitor, footswitch control, floppy drive, 120 GB hard drive, CD-Rom drive, SmartMedia card slot, USB, etc, etc, etc.
The Multistation MSX would be your best bet. |
jens.luehmann
Posted: Tue Sep 26, 2006 1:25 pm Post subject:
Stage Tracker 1.0 |
here is another interesting live-sequencer.
Stage Tracker at www.stagetracker.com
It´s brilliant!
jens |
hedswell
Joined: Feb 16, 2006 Posts: 3 Location: manchester, UK
Posted: Thu Apr 19, 2007 11:24 am Post subject:
Re: Stage Tracker 1.0 |
| jens.luehmann wrote: | Hi,
It´s brilliant!
jens |
This won't play the demo on my laptop  _________________ The earth meets the sky over the hill. I was told this by a sparrow with a lump on it's head.
Ivor Cutler. |
Posted: Sun Apr 22, 2007 7:19 am Post subject:
Why not continue using Garageband for now?
An altenative is playing the songs off midi and use inexpensive older midi synths for some of the sounds? Then you play along to this? _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Dayflight
Posted: Tue Sep 04, 2007 5:47 am Post subject:
Sequencer Subject description: Live Performance |
look under Genoqs Octopus for a fine Hardware Sequence for Studio and Live work.
[editor's note: see this topic http://electro-music.com/forum/topic-20197.html --mosc] |
seraph
Editor
Joined: Jun 21, 2003 Posts: 12010 Location: Firenze, Italy
Audio files: 31
Posted: Tue Sep 04, 2007 12:56 pm Post subject:
Re: Sequencer Subject description: Live Performance |
| Dayflight wrote: | Hi,
| hjnewcomb wrote: | | im in a bit of money problemos atm |
Dieter
I don't think he's gonna choose the Octopus
 _________________ homepage - blog - forum - youtube
| Quote: | | Politics is the entertainment division of the military industrial complex - Frank Zappa |
tobaggo
Posted: Fri Jan 11, 2008 4:38 am Post subject:
It's on PC but you have Usine at www.sensomusic.com
very interesting outsider... |
ark
G2 patch files: 31
Posted: Sat Mar 08, 2008 12:54 pm Post subject:
| A well-designed, inexpensive sequencer (with editing capabilities that include audio tracks) that I've used on a number of occasions is Midi Maestro, midimaestro.com |
