Joined: May 16, 2005 Posts: 8902 Location: Birmingham, England, UK
Posted: Sun Apr 09, 2006 2:28 am Post subject:
| elektro80 wrote: | But what about a "comfy chair" smiley? For those moments you just know you have a captivated audience?  |
spooky- I was actually thinking od a 'pipe and slippers at the fire' emoticon
(or should that be 'on the fire'???  _________________ ACHTUNG!
Posted: Sun Apr 09, 2006 2:32 am Post subject:
Getting back to the Linux thingie, I think I may just get a larger HD and partition it into 2 sections.
I'm still in the Mac OSX school of thinking where the drive doesn't need to be partitioned. But we are talking two separate OS's here arent we?
How much of a HD hog are Linux and XP? I bet XP is a bastard for eating HD??? _________________ ACHTUNG!
Joined: Jan 31, 2003 Posts: 17337 Location: Allentown, PA
Audio files: 107
Posted: Sun Apr 09, 2006 5:25 am Post subject:
| v-un-v wrote: | | I ripped Carlo's head off because it was a complete coincidence that I happenned to be fuming about that very RTFM emoticon moments earlier. |
Well, I'm not for ripping anyone's head off, especially Carlo's, but I'm glad you spoke up about that RTFM icon. I think the Ubuntu forum has a good attitude about respect which is what we have here BTW. They have done a better job of expressing it. I'm going to lift some of that wording and add it to our conditions of use statement. I think one could say, "it's in the manual" instead of RTFM.
 _________________ --Howard
my music and other stuff |
Audio files: 107
Posted: Sun Apr 09, 2006 5:27 am Post subject:
OSX needs disk partitions too.  _________________ --Howard
seraph
Editor
Joined: Jun 21, 2003 Posts: 12010 Location: Firenze, Italy
Audio files: 31
Posted: Sun Apr 09, 2006 5:56 am Post subject:
| elektro80 wrote: | | Blue Hell wrote: | | I did read Carlo's emoticons as irony, as humour. not as cynic even. |
I read this the same way Jan did. |
I deeply apologize if anyone felt offended. please remove the f***ing emoticon in order to sanitize the forum I stupidly thought that if it was there (the emoticon) I was allowed to use it without being censored but maybe I was wrong, anyway...I don't even know what ubuntu is  _________________ homepage - blog - forum - youtube
| Quote: | | Politics is the entertainment division of the military industrial complex - Frank Zappa |
Posted: Sun Apr 09, 2006 12:15 pm Post subject:
| mosc wrote: | OSX needs disk partitions too.  |
Yes. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Posted: Sun Apr 09, 2006 4:18 pm Post subject:
| mosc wrote: | | I think one could say, "it's in the manual" instead of RTFM. |
One of the main problems is that a lot of this computer stuff hasn't got a decent manual at all- so RTFM bares no relavence anyway.
In my experience of software- a lot of the time it's a well written manual that makes good software a hit.
Okay sometimes this isn't always the case- as good software should be easy to figure out, but for the majority of times this isn't the case.
I really don't like manuals at all- especially having to build a picture of what is to be achieved in my head by having to collate info from various opinions on a web forum.
Some people would call this being lazy. I strongly dispute that. It's about having the powers to concentrate on a single item in mind. Some people are good at this- some aren't. I most definately fall in to the second catagory.
I don't think we need an emoticon like rtfm at all. Our list membership is 3000+ (?) I'm sure there are enough people here willing to help out? _________________ ACHTUNG!
Posted: Sun Apr 09, 2006 4:20 pm Post subject:
| seraph wrote: |
I deeply apologize if anyone felt offended. |
No probs Carlo. It was just the wrong thing at the wrong time. Anyone can make that mistake- I'm no angel either
Tom _________________ ACHTUNG!
Posted: Sun Apr 09, 2006 9:07 pm Post subject:
If you liked Ubuntu, you might also like Knoppix. It's probably the most "famous" of Live CD's, because it was basically the first (or at least, the first very successful Live CD). Both are derivatives of Debian Linux, which has a strong "Open Source Only" attitude, though these derivatives are a bit more lazy about that.
Knoppix, however, can also be installed into a windows directory!
Try this:http://www.knoppix.net/wiki/Win_Partition
I've haven't found any info on this for Ubuntu, but it may also be possible.
If you do install to it's own partition on a new drive, you will do a couple of things:
1.) Create a new partition for Linux's SWAP partition. This is basically an extension of your RAM into your hard disk. Both Windows and Macs do this as well. Linux keeps a seperate partition for it, so it can not corrupt, or be corrupted, by the other partitions of programs running. This is usually 2x your RAM size.
2.) Create a /boot directory. This is usually very small, like 50MB or so. It handles only the boot stuff, and is generally formatted as "ext2" type. I'll explain below.
3.) Create a /root partition. This will hold everything for the install, if you so choose. You can go further, and create partitions for "/home" and "/var". /home is YOUR USER data. Most of your personal data and files is kept here. /var is for extensions to the linux install, compiling your own programs from source, etc. Again, these are broken up for performance, stability, and security. It's rolled over from the days when drives where small, and a unix install would support hundreds of user accounts. I'd recommend just going with "/root", and linux will handle everything from there.
Notes on File System(FS) Types:
Windows uses 2 basic FS types: NTFS and FAT32. FAT32 is older. NTFS is newer, and more stabile. This is what you probably have XP installed as. You'll notice, if windows crashes, it doesn't run a "check disk" utility, like it used to in win98. That's because NTFS is a journaled file system, so on the disk, the OS keeps track of the work it is doing to & from the disk. So if anything crashes, it can re-trace it's steps and files won't get corrupted.
In Linux, there are MANY types of partitions. Choices, choices. Some are older but always still supported, some are designed for speed, smaller files, or for stability. Linux can access FAT32 drives, and can read NTFS, but can't write to NTFS reliably just yet. So if you ever want to pass data between Linux & windows on the same PC (like saving .wav files, or MP3's that you might access in both realms), create a FAT32 for data on this new drive of yours.
The most common and "stabile" (read- tested & proven) filesystem in Linux is EXT3. EXT2 is older, and used for things like boot because it's simple. EXT3 is a nice balance for small & large file sizes, and good performance. REISERFS is the next step, and added Journaling (like NTFS copied). I like REISERFS the best, and if offered, you should choose this one. It is one of the fastest at handling most file sizes, and is very stabile in not corrupting data due to bad disk accesses, etc. It might not be the default, so look for it during the install. |
Posted: Mon Apr 10, 2006 1:02 pm Post subject:
I've found a few "drivers" for windows. I've not tested yet, but will post here anyway. They give Windows access into Linux partitions!
for ReiserFS:
http://rfsd.sourceforge.net/
for EXT2 and EXT3:
http://www.fs-driver.org/index.html
So, you won't need those ugly FAT32 partitions to exchange data between Windows and Linux!! |
brinxmat
Posted: Wed Jun 28, 2006 12:54 pm Post subject:
I should have posted this earlier…
]https://wiki.ubuntu.com//WindowsDualBootHowTo
It explains how to resize an existing windows partition. I reckon that you will need 10Gb for a working linux install. The swap space should be big enough at 500Mb, leaving 9.5 ± Gb for the system and fun.
This approach worked fine for me, but as always, make a backup of anything you CAN'T afford to lose.
Note that XP should always be installed first anyway! _________________ -- Say "&Eth;onne hit wæs hrenig weðer" |
zynthetix
Audio files: 10
G2 patch files: 13
Posted: Thu Jul 20, 2006 5:05 am Post subject:
Thanks for the ubuntu links everyone!
I've put two of them in the links section for further reference (under the Audio and Computer Resources section).
(being a proper moderator for a short while again.....every little bit helps?? ) _________________ ACHTUNG!
make
Posted: Sat Dec 09, 2006 10:31 am Post subject:
I run a dual boot desktop with Linux & XP and this is my working method:
I like to keep both XP and Linux on separate HDD's so this is only good if you have 2 [at least]. I have a drivebay and only one dvd drive so I tend to run 3 hdd's.
1: Remove all hdd's and re-insert HDD1 which will have the XP installed on it. Remember to set this drive up with the pins on the back as the master.
2: Install XP.
3: Remove HDD1, reconfig pins so this is the slave/secondary drive and then reinsert into drivebays in the secondary position on the IDE belts.
4: Insert HDD2 which will have Linux installed on it, having set up the pin config as the master and place into the primary position in the drivebay.
5: Install your flavour of Linux.
Im sure that the Linux distro will see that there is another [non-linux] OS on the other drive and so will write this into GRUB as a boot option.
You [should] have now successfully installed both OS's on differing HDD's and they are now accessible by either changing the boot order in BIOS or by using GRUB as a boot loading chooser.
Hope this helps. If it doesn't then... [insert emoticon that is purile and signifies to go RTFM & STFU while tongue is sticking out but remaining firmly in cheek].  |
Audio files: 107
Posted: Sat Dec 09, 2006 12:48 pm Post subject:
| v-un-v wrote: | | elektro80 wrote: | But what about a "comfy chair" smiley? For those moments you just know you have a captivated audience?  |
(or should that be 'on the fire'???  |
