sheridan
Joined: Jun 05, 2005 Posts: 473 Location: London, England
Audio files: 27
Posted: Mon Apr 17, 2006 11:27 am Post subject:
BCR ctrl synth 3 - HardwareSynthArchitecture with mod matrix Subject description: 4 Oscs, 4 LFOs, 3 Envs, 2 Filters, AM, FM, Saturation, Delay, with most controls mapped to BCR2000. |
Hi there.
Here is an updated version of a synth that I posted ages ago on the forum. If you're looking for unbelievable and previously unheard sounds, then I'm afraid to say that you probably won't hear too many using this synth. However, if you're looking for staple sounds, ie. bass, strings, leads, etc., then you've come to the right place.
This synth features 4 Oscs (each with Sync, Pitch, FM and Shape modulation options), 4 LFOs, 3 Envs, 2 Filters (with velocity and modulation options), AM (with various sources), modulatable Panning, Saturation, and finally, a Stereo Delay. There are also a variety of modulation sources for many mod inputs.
The best bit of this synth (for me anyway ) is that the majority of parameters are mapped to the controls on my (Behringer) BCR2000... I have a G2 engine if you hadn't guessed. So, using my BCR2000 with this patch enables me to get the most out of it. I can heartily recommend it to other engine users.
I have attached the BCR2000 patch along with a screenshot and the G2 patch for anyone else who may already have one. In the post below, I have attached the control list for these patches
I regularly use this synth to quickly come up with a sound that is close to the sound that I'm after and then tweak the patch from there. When I have the right sound, I simply delete uneccessary modules (usually to around a 40 cycle patch load) to free up extra polyphony. It's a great time saver, even with the final deleting process.
I hope it helps you as much as it has me.
I put this synth, a BCR Ctrl Synth 4 and a Drum machine patch together with some sequencers in a performance which will give you some idea of the sounds in action: http://electro-music.com/forum/topic-11215.html
Description: |
Screenshot of the BCR ctrl synth 3 patch. |
Filesize: |
437.69 KB |
Viewed: |
513 Time(s) |
Description: |
MIDI file with BCR2000 preset to control BCR ctrl synth 3 - play file to BCR2000 to load into current preset. |
Download |
Filename: |
G2 Synth control by BCR2000.mid |
Filesize: |
16.68 KB |
Downloaded: |
617 Time(s) |
Description: |
BCR ctrl synth 3 patch: 4 Oscs, 4 LFOs, 3 Envs, 2 Filters, AM, FM, Saturation, Stereo Delay, with most parameters mapped to a BCR2000 preset. |
Download |
Filename: |
BCR ctrl synth 3.pch2 |
Filesize: |
5.41 KB |
Downloaded: |
1560 Time(s) |
_________________ Sheridan
http://www.nitetimeproductions.co.uk Last edited by sheridan on Wed Sep 06, 2006 4:45 am; edited 4 times in total |
sheridan
Audio files: 27
Posted: Mon Apr 17, 2006 11:30 am Post subject:
Control list for BCR2000. .jpeg and Word Document (easier to see).
Description: |
Control list for the BCR2000 patch attached above. |
Filesize: |
488.58 KB |
Viewed: |
481 Time(s) |
Description: |
Word document with control list for attached BCR2000 patch. |
Download |
Filename: |
G2 main setup patch for BCR2000 v3.doc |
Filesize: |
70 KB |
Downloaded: |
625 Time(s) |
http://www.nitetimeproductions.co.uk |
Fozzie
G2 patch files: 49
Posted: Mon Apr 17, 2006 12:30 pm Post subject:
Wooohooo, I have the same hw combo, so I applaud this great set of files |
