 Forum index » Instruments and Equipment » Waldorf
XT Arp--External Clock Sync?
Page 1 of 1 [9 Posts]
Mohoyoho
PostPosted: Mon Apr 24, 2006 2:19 pm    Post subject: XT Arp--External Clock Sync?
Subject description: Can't get external sync for arp
I am trying to get my XT to sync to my Q Rack's arp tempo, but I havn't been able to get it to work. I have the Q sending, and the XT I have tried to sync external, but to no avail. Is this a bug, or am I doing something wrong?
Mark Mahoney
Kingsport, Tennessee
www.cdbaby.com/cd/markmahoney
PostPosted: Mon Apr 24, 2006 2:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm, I have heard someone complain about the very thing recently.. but I cannot quite remember if this truly is a bug or an OS feature or whatever.
Question
egw
G2 patch files: 8
PostPosted: Mon Apr 24, 2006 3:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
I sync my XT to an external clock, so it should be possible.
AnalogAssailant
PostPosted: Mon Apr 24, 2006 3:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
I agree egw, i sync my XT all the time (with logic audio mind you) so what you're trying to do should work.
Mohoyoho
PostPosted: Mon Apr 24, 2006 4:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've got my Q rack hooked to the XT via the Midi Thru of the Q to the In on the XT. On the Q's Global I have it sending midi info. The XT I have set for receive MIDI. When I'm in an arp, I change the clock to internal and/or external. Neither clock setting will allow me to get the same tempo as the Q. What am I doing wrong? I want the Q to set the tempo for the XT.
Mark Mahoney
Fozzie
G2 patch files: 49
PostPosted: Tue Apr 25, 2006 12:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Could it be that the clock is only sent on midi out? Would make sense to me that it is not sent on midi thru.
Mohoyoho
PostPosted: Tue Apr 25, 2006 6:30 am    Post subject: Reply with quote  Mark this post and the followings unread
That makes sense. I'll check that out. But how would you get two modules sync'd together? I tried going Midi Out from the Q to the XT and nothing worked.
Mark Mahoney
egw
G2 patch files: 8
PostPosted: Wed Apr 26, 2006 9:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Are you sure that your Q rack is sending clock?
If it is also synced externally, it won't send clock out.
Normally, midi out only contains signals generated by the device.
And midi through contains only signals that come into the midi in, not genreated internally.
Mohoyoho
PostPosted: Wed Apr 26, 2006 5:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
It seems the only way I'll be able to do this with a rack is to somehow merge the midi with some kind of merge device.
Mark Mahoney
Niio2
