Yawgmoth
Joined: Mar 09, 2006 Posts: 24 Location: Grou - Holland
G2 patch files: 7
ian-s
Joined: Apr 01, 2004 Posts: 2518 Location: Auckland, New Zealand
Audio files: 42
G2 patch files: 584
Posted: Fri Apr 28, 2006 1:28 pm Post subject:
| Use a LFOB sawtooth (set to clock sync 1/16 if you like) to clock your sequencers. Add an extra valseq for the gate times, patch the LFO sawtooth and the gate time sequencer to a cmpval module and use its output as your gate. You get variable gate time from 0-100% in 128 steps which means it also does rests and ties. |
sheridan
Joined: Jun 05, 2005 Posts: 473 Location: London, England
Audio files: 27
Posted: Sat Apr 29, 2006 5:43 am Post subject:
Not quite sure exactly what you're after, but if you click on the T (trigger) button on the NoteSeq and change it to G (gate), you can then link consequecutive notes to make longer notes. _________________
Sheridan
Hear music and Nord Modular G2 patches and find out music production tips at
http://www.nitetimeproductions.co.uk |
Yawgmoth
G2 patch files: 7
Posted: Sat Apr 29, 2006 6:14 am Post subject:
| sheridan wrote: | | Not quite sure exactly what you're after, but if you click on the T (trigger) button on the NoteSeq and change it to G (gate), you can then link consequecutive notes to make longer notes. |
That's it! So dum of me not knowing this anymore, i've NM for 3 or 4 years
Thx for all reply's |
mininanowave
Posted: Sat Apr 29, 2006 12:11 pm Post subject:
but what happens when you want to hold note for 16 steps and then you reset loop but sequencer still holds note. is there better way that T? like hold note for 15 steps and hit new note on step 16? how to do this?
mininano.
my g2 is 2 pc's with g2demo Last edited by mininanowave on Sun Apr 30, 2006 8:54 pm; edited 1 time in total |
Posted: Sat Apr 29, 2006 2:23 pm Post subject:
You replace sequencer with "pulse" module followed by the logic inverter over "sync" signal patched. No use sequencer no more; no needed expensive module for that. Sequencer lots of knobs and schreen space only it's the confusing extra. little small few sample latency no matter for the long notes. Take the easy cheap way in that place.
Also next time you use the "sentence structure" sub patch, no excuse if from USA, me spend long time decoding you words. _________________ Kassen |
mininanowave
Posted: Sat Apr 29, 2006 3:05 pm Post subject:
| Quote: | | Also next time you use the "sentence structure" sub patch, no excuse if from USA, |
sorry about my bad english. i am in america temporarily.
| Quote: | | You replace sequencer with "pulse" module followed by the logic inverter over "sync" signal patched. |
what do you mean here? can you post a patch?
mininanowave |
ian-s
Audio files: 42
G2 patch files: 584
Posted: Sat Apr 29, 2006 10:16 pm Post subject:
The problem with gate mode is you loose the ability to have two or more consecutive 16th notes.
A gate width conrol input (as a % of tempo) would have been handy on the clock module. |
Unfed
Joined: May 11, 2004 Posts: 200 Location: Rochester, NY
G2 patch files: 11
Posted: Sun Apr 30, 2006 9:24 am Post subject:
wasn't this resolved somehow, maybe by sending a pulse from another sequencer to retrigger the envelope at a certain step? _________________ SoundCloud |
dasz
Joined: Oct 16, 2004 Posts: 1624 Location: vancouver, canada
Audio files: 29
G2 patch files: 56
mininanowave
Posted: Sun Apr 30, 2006 8:56 pm Post subject:
dasz
your patch looks very good for what i want. i can reset with 2nd row to interrupt connected holding notes on 1st row (step 12 and step 1 reset even when T is on row 1). very happy
i see you made sounds with g2 factory banks. very nice sounding, and different sometimes when your morphing.
mininanowave Last edited by mininanowave on Sun Apr 30, 2006 9:04 pm; edited 1 time in total |
mininanowave
Posted: Sun Apr 30, 2006 9:01 pm Post subject:
kassen, it is ok. i am trying to improve my english here in usa. and i am thinking if i should buy g2 engine here too. it has it 120/240v switch, correct? i do not know how to do electronics (just electronic music).
mininanowave |
dasz
Audio files: 29
G2 patch files: 56
Audio files: 215
G2 patch files: 92
mininanowave
Posted: Sat May 06, 2006 5:56 pm Post subject:
thank you too antimon,
i like holding notes this way too. your patch combined with dasz patch make very rich sequences.
thank you 2 guys
now help me, should i get g2 engine or g2 keyboard (but it is so much more expensive). i dream of the g2 keyboard. even i when i look on ebay, the price is still high.... i like the keybaord because of 808 style sequencer programming mode (some said this on electromusic).
maybe i need to sell something else (i have enough for a engine), and i have a dp/4 that a g2 may replace well (4 input and 4 outputs of effects) ... how much is a dp/4 worth?
mininano |
Rob
Joined: Mar 29, 2004 Posts: 578 Location: The Hague/Netherlands/EC
G2 patch files: 109
Posted: Sun May 07, 2006 10:37 am Post subject:
Re: How too make a note gate longer then 1/16 th? |
| Yawgmoth wrote: | | Now I want too make notes sound longer then 1/16 th. How can this be programmed? For example: 1/16, 1/16, 2/16, 1/16 and 4/16 as a sequence. |
I posted an example in the Buildingblock section:
http://electro-music.com/forum/post-76684.html#76684
/Rob |
mininanowave
Posted: Sun May 07, 2006 11:16 am Post subject:
wow another way too from rob! i really want a g2 now! the demo does not have enough power...
mininano |
Posted: Mon May 08, 2006 12:48 am Post subject:
| mininanowave wrote: |
I wouldn't do that. For the things they have in common the DP/4 knocks the G2 around the block. I seriously doubt anybody will ever make a multi-fx like those Ensoniq's again. _________________ Kassen |
ian-s
Audio files: 42
G2 patch files: 584
Posted: Mon May 08, 2006 1:34 am Post subject:
| You should try and get some hands on time with the G2 key. It's user interface does not suit everybody. Looks better on paper than it does in practice. IMO it is like tweaking through a mail slot. |
davep
Joined: Jul 05, 2004 Posts: 465 Location: Oakland, CA
Audio files: 10
G2 patch files: 73
Posted: Wed May 10, 2006 2:05 pm Post subject:
In case someone else hasn't thought of this method -
How about using a SHAPE LFO set to pulse wave, and sync'd to midi clock, and using a level Seq or value seq (clocked from midi sync'd clock module) to control the pulse width of each cycle of the LFO? This varying-width midi-sync'd pulse would then be used to gate the EGs. _________________ Dave Peck |
