today> Muied Lumens Frequencies
Sequencer problem.. bug??
Page 1 of 1 [7 Posts]
jamos
G2 patch files: 39
PostPosted: Tue May 09, 2006 3:02 pm    Post subject: Sequencer problem.. bug?? Reply with quote  Mark this post and the followings unread
I'm trying to build a very large song-sequencer - something that sends mute signals to sequencers in other slots via the buses. It works well, but something went wrong when I tried to double the number of modules: now two of the sequencers won't go into Park mode, no matter what.
The patch is attached - it resides in slot D in my performance. Note the two red sequencers: they will not go into park along with the others. I've checked all the connections; disconnected them and reconnected; changed the module order; even deleted them and added them again from scratch.
I originally had "only" 16 sequencers, and it worked correctly. The problem occurred sometime after I copied and pasted the 16 sequencers (didn't notice it at first.) Any suggestions?
SequencerControl.pch2
Load in slot D. What's wrong with the red sequencers?
 Filename:  SequencerControl.pch2
 Filesize:  13.25 KB
 Downloaded:  1151 Time(s)
Audio files: 248
G2 patch files: 319
PostPosted: Tue May 09, 2006 3:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Do those sequencers actually not run or are only the lights not working ?
jamos
G2 patch files: 39
PostPosted: Tue May 09, 2006 4:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
They don't run properlyy either - at least, the step lights don't work. I didn't bother analyzing sound at that point, mostly because -
I fixed the problem. Simply deleting the lower right set of modules - the output multiplexer - and then undoing that, caused the sequencers to straighten out.
So it's definitely a bug. Should have posted in that forum.
Audio files: 248
G2 patch files: 319
PostPosted: Tue May 09, 2006 4:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wel, I was asking because there is an issue with too many lights, and your patch has quite a few.
3phase
G2 patch files: 141
PostPosted: Tue May 09, 2006 6:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
it seems that the usually very good working auto optimisation algorhytm has sometimes problems..
Sometimes it helps to move modules to other positions... also the delete and replace of some modules, as you have done it, can force the algorhytm to recalculate the runing order in a different way.
It however happens rarely...for me ,as i said, its mostly an issue with complex sequencers.
mother misty
G2 patch files: 130
PostPosted: Wed May 10, 2006 1:04 am    Post subject: Reply with quote  Mark this post and the followings unread
There is a problem when there are too many lights in the editor.
I hope they fix it one day. I've several patches which don't "seem" to work because the lights don't work properly, but they do work properly.
Very annoying Sad
Fozzie
G2 patch files: 49
PostPosted: Wed May 10, 2006 1:34 am    Post subject: Re: Sequencer problem.. bug?? Reply with quote  Mark this post and the followings unread
jamos wrote:
.......it resides in slot D ......
Shocked alien Shocked
*flashback to G1 slotD bugstories*
Nahhh, it MUST be the lights thingie Wink
