Dexter76
Posted: Thu May 25, 2006 7:45 am Post subject:
MC909+ Cubase Midi Multitrack recording |
Greetings,
i'm looking for a way to record the 16 parts of my MC 909 into 16 separate tracks in CUBASE 3 SX.
The groovebox is master and midi out to my sound card (midi in port)
I open a multitrack session in cubase (16midi tracks) but i don't know how to assign the track 1 in cubase to track 1 of my Groovebox, track 2 to track 2...etc..so that the 16 tracks can be recorded separately and simultaneously when they play.
Any suggestion?
Thank you in advance
Rgds
DX76 |
paul e.
Joined: Sep 22, 2003 Posts: 1567 Location: toronto, canada
Posted: Thu May 25, 2006 7:59 am Post subject:
each 'track' in mc909 should correspond to a midi channel
track 5 = midi channel 5
? _________________ Spiral Recordings |
Dexter76
Posted: Thu May 25, 2006 8:20 am Post subject:
Yes.
I've installed a patch (script) that let Cubase recognize my MC909 as output device. The problems are from MC909 to Cubase.
When i play a part on my MC909, for example part 1 and i want to record it just on the track 1 on cubase, it's recorded on all the tracks.
In other terms i cannot split and assign the 16 channels that comes from my 909 to cubase. |
Dexter76
Posted: Sat May 27, 2006 1:20 am Post subject:
No one can help me out?
Regards
DX76 |
make
Posted: Mon Aug 28, 2006 6:23 am Post subject:
So you are trying to record 16 midi channels from your groove box?
Are the individual channels set up correctly from the MC909? IE: each instrument is set to its own midi channel?
If all the data is being recorded in but not separated then it might be a couple of things:
*you haven't armed all the 16 channels to record at once or they are not set correctly what channel to listen to.
*the cubase channel is recording all the data on one channel but then you can separate it using a function called "dissolving midi". You can then split the midi in various ways: by midi channel or by pitch |
