Gothboy
Joined: Feb 21, 2006 Posts: 369 Location: Santa Monica, Ca.
Posted: Fri May 26, 2006 11:25 am Post subject:
Syncing 2 Computers |
Is it possible to SMPTE sync 2 computers? Say you wanted to run Reason on one and Pro Tools on another... but have one slaved....any way to do this and How? _________________ Apple Mac Pro 3.1 2.88 GHz. Intel Xeon Quad
16 GB Ram
10.8.5/El Capitan
Novation SL49/Remote Zero
Mophox4, Nord Lead 2, Roland System 1, Novation Nova, Nord Micro modular, Korg Radias, Roland d-05, Yamaha A3000 sampler, Novation SL MK2 and Remote Zero controllers, Arturia Beatstep and SparkLE
Dymaxion Vehicle Music at www.dymaxionvehicle.com/ |
Posted: Fri May 26, 2006 12:09 pm Post subject:
This is going under the assumption you want to synchronize audio/midi data and not video.
If you are interested in synchronizing a sequencers START, STOP, PAUSE and TEMPO between two computers then you would want to be using MIDI CLOCK. The MIDI protocol sends 24 clock messages (actually "F8" HEX)each second to synchronize one or more instruments to a single master Thus, the master would generate the MIDI clock and the slave would receive this clock. The physical connection traditionally is done over a standard MIDI bussing arrangment.
As for specifically how to do it with those programs, a look at the MIDI settings will quickly tell you as I don't own or use either program.
I hope I help. |
Gothboy
Posted: Fri May 26, 2006 4:50 pm Post subject:
Ummmm........yeah, I know how to use midi sync and know the concepts involved.......just how do you do it with 2 computers? _________________ Apple Mac Pro 3.1 2.88 GHz. Intel Xeon Quad
16 GB Ram
10.8.5/El Capitan
Afro88
Audio files: 12
G2 patch files: 79
Posted: Fri May 26, 2006 7:49 pm Post subject:
Gothboy wrote: | Ummmm........yeah, I know how to use midi sync and know the concepts involved |
What's the problem then?
Set one computer to send the MTC out one of it's midi outputs, and set the other computer to receive MTC on one of it's midi inputs. Connect with a MIDI cable.
Sometimes they might both play at exactly the same tempo but don't hit beats at exactly the same time though. Turn on both computer's metronomes and play with the MTC delay setting until the metronomes are perfectly in sync. When I sync my MPC to Ableton I have to set the delay to nearly -30ms for them to be perfectly in sync even though I'm only running at 3ms latency. Just one of those things I guess |
Posted: Fri May 26, 2006 8:26 pm Post subject:
Woops, a bit sensitive there . I had absolutely no intension of insulting your intelligence. Just trying to be helpful, that's all. SMPTE is usually used to synchronized audio and video from multiple camera angles and figured I would point you in the right direction. Maybe I misunderstood your question. |
