Posted: Wed May 31, 2006 2:04 am Post subject:
Okay Daniel,
looks like there's an Uncle Krunkus stripboard version of the DS7 happening tonight. Well, I've got about 25 spare LM13700s so it will be a dual DS7 stripboard. Something new might get me moving again. I've kinda been a bit stuck lately. _________________ What makes a space ours, is what we put there, and what we do there. |
Posted: Wed May 31, 2006 5:16 am Post subject:
Hey Daniel,
have you got a component overlay for the dual DS7 w LM13700 PCB layout?
Sometimes it helps with getting the stripboard tight.
Thanks _________________ What makes a space ours, is what we put there, and what we do there. |
dnny
Joined: Mar 12, 2005 Posts: 519 Location: Helsinki, Finland
Posted: Wed May 31, 2006 5:47 am Post subject:
Uncle Krunkus wrote: |
Thanks |
i don't have a component overlay but you can use the bareilless one - just ignore the CA8030 and proceed as shown here
bareiless overlay
_________________ Association of experimental electronics
www.koelse.org
flickr: cable porn group |
dnny
Posted: Mon Jun 19, 2006 8:17 am Post subject:
looking good!
You are the master of Loch Master.
thanks for doing this _________________ Association of experimental electronics
www.koelse.org
zipzap
Posted: Mon Jun 19, 2006 11:20 am Post subject:
Hey, that´s some art! Enjoy doing that? Looks like a puzzle (to get from the circuit to that layout). And i think it´s built as quick as using a pcb!
And no cpu around
What´s the thing labled ATE on the top left? |
dnny
Posted: Mon Jun 19, 2006 11:28 am Post subject:
zipzap wrote: |
that must be the 7805 voltage regulator. _________________ Association of experimental electronics
www.koelse.org
zipzap
Posted: Mon Jun 19, 2006 12:07 pm Post subject:
I see. Never noticed in the schematic that it´s run on 5v. Could be 12 or 15 just the same i guess. |
Posted: Mon Jun 19, 2006 12:16 pm Post subject:
Yeah,
I wasn't sure why it's regulated down to 5V, but I just copied the schematic. Maybe you should try shorting it out and see what happens. I bet with a 9V battery and no regulator the envelope follower contaminates the VCO. _________________ What makes a space ours, is what we put there, and what we do there. |
Posted: Mon Jun 19, 2006 12:22 pm Post subject:
BTW,
there are 35 wire links. I always do all the cuts first. Then the IC sockets, then the links, so that by the time you get to the components which look different from each other you have plenty of 'landmarks' to guide you. _________________ What makes a space ours, is what we put there, and what we do there. |
zipzap
why?
your second post was quick...
I mean why contaminate? |
dnny
Posted: Mon Jun 19, 2006 12:27 pm Post subject:
zipzap wrote: | I see. Never noticed in the schematic that it´s run on 5v. Could be 12 or 15 just the same i guess. |
take a good look at the schematics and you will notice it
yes,you can feed the 7805 whit 12V or 15V and that's just fine. i have used it whit 9V battery. _________________ Association of experimental electronics
www.koelse.org
dnny
Posted: Mon Jun 19, 2006 12:32 pm Post subject:
post are flying in like moskitoes
the original DS-7 runs on 9V battery and the schematic is cloned from it, so there must be a reason why the original has the regulator and not just the battery. _________________ Association of experimental electronics
www.koelse.org
Posted: Mon Jun 19, 2006 12:34 pm Post subject:
Because when C1 starts to charge you get a quick virtual short across the power which is probably too much for C20 to deal with by itself. It would only make the tone slide a bit (which it does anyway)
Well that's only a theory, you'd have to check it out with someone a bit more qualified than me to be sure. Maybe Jan or Stein. _________________ What makes a space ours, is what we put there, and what we do there. |
Posted: Mon Jun 19, 2006 12:39 pm Post subject:
Yeah,
if it's designed for a 9V battery it makes sense to have the circuit set up for 5V, then you overshoot the regulator by 4V and you have a rock solid 5V rail. More reliable. _________________ What makes a space ours, is what we put there, and what we do there. |
zipzap
Posted: Mon Jun 19, 2006 12:43 pm Post subject:
The differnt parts of the schematic look to me like stuff i find in my modular, running with 12v.
The thing about the short with c1 is interesting. guess you meen c2 can´t handle. But also cabs going to ground, charging and discharging can be found often, in envs, lfos mad many other.
you guys type too quick i can´t get this posted |
zipzap
Posted: Mon Jun 19, 2006 12:45 pm Post subject:
solid 5v from battery. Sounds very reasonable. |
Posted: Mon Jun 19, 2006 1:27 pm Post subject:
It's strange that we don't go to the chat room in a situation like this. I guess the electro-music crowd just aren't much into chatting. I've been in there to see if anyone is around about a dozen times now and I've never found anyone!
BTW, No, I meant C1. I kept all the designators the same as the schematic and just made the 10uF power cap C20 for clarity. Otherwise it's the same as the PCB (which has a number of pins on the 324s different to the schem) _________________ What makes a space ours, is what we put there, and what we do there. |
creekree
Joined: Mar 30, 2006 Posts: 192 Location: Morgenland Neukölln
Posted: Mon Jun 19, 2006 1:30 pm Post subject:
he guys,
my ds7´s volume is too low, i really have to turn the gain on my mixer WAY UP in order to work with it. how to make the thing louder? i guess it is about changing a resistor value, but in all honesty i have no idea of where to start...
thanks, christian |
Posted: Mon Jun 19, 2006 5:40 pm Post subject:
R33(10K), sits between C6 and one side of the volume pot. Try changing it down to 5K6. _________________ What makes a space ours, is what we put there, and what we do there. |
creekree
Posted: Sun Jun 25, 2006 3:05 pm Post subject:
unkle krunkus,
i replaced the resistor, i soldered a second 10k parallel to the first one, i did what i could... the overall volume didnt improve that much.
anywhere else to look at?
creekree |
Posted: Sun Jun 25, 2006 4:39 pm Post subject:
Are you sure you've got the volume pot connected properly? Try shorting the output straight to R33 (turn your amp down!) _________________ What makes a space ours, is what we put there, and what we do there. |
dnny
Posted: Fri Jul 21, 2006 1:13 am Post subject:
i got a PM and i touhgt it would serve everybody better if it's posted here.
DiscoFreq wrote: | Hi,
I'm the guy from http://filters.muziq.be (about effects, but also with drum synths etc).
I built myself a small modular of DS-7, DS-8 and Amdek PCK-100 Drum Synths. I received mod info from Marc Bareille for the CV input on the Corons, but then they can not be triggered anymore when there's a jack in that socket. They just make sound as long as there's a CV on that input.
Is that the same with your CV mod?
Another problem I have is that I can trigger the Amdeks with a voltage trigger or audio trigger, but the Corons only respond to audio triggers. Any idea if this can be solved? |
Hi DiscoFreq.
Your DiscoFreqFX-site is great! i have visited your site many times before. thanks.
Actually a haven't made any CV mod. but i have made the VCA mod - its for signal only and i have use it as noise input.
Do you have a schematic of that CV mod Marc sent you?
My DS7 can be triggered whit mostly anything, never had problems?
So maybe there are other members of this forum that know better
i know there are.
and to electro-music.com forum
daniel _________________ Association of experimental electronics
www.koelse.org
zipzap
Posted: Fri Jul 21, 2006 1:30 am Post subject:
Cool site! never been there before. lots of stuff to check out and a nice collection of schematics (Böhm Trickverzerrer! i like that stuff) |
