 Forum index » Clavia Nord Modular » G2 Patches - Completed » FX
superChorus
Page 1 of 1 [2 Posts]
ian-s
Audio files: 42
G2 patch files: 584
PostPosted: Mon May 29, 2006 4:12 pm    Post subject: superChorus
Subject description: 16 phase chorus with ichicoo park mode
Most chorus effects rely on multiphase LFO’s modulating two or more delay lines. Early units like in the Polysix used 3 waves spaced apart by 120Deg. Using 4 delays you can get buy with 2 modulating waves because the second pair can be derived by simple inversion. So if you have A = 0 deg and B = 90 deg then 180 deg = -A and 270 deg = -B.
This holds for all cases where the number of delays is a power of 2. Here is a super chorus which uses 16 delay lines.
It has an unusual feature which is modulation depth modulation. This is because when using triangle LFO waves, the effect is a comb filter and shifting the modulation depth, shifts the notch frequency, see variation 4. Closest thing I’ve heard to real ‘flanging’.
superChorus.pch2
16 phase chorus
 Filename:  superChorus.pch2
 Filesize:  4.48 KB
 Downloaded:  926 Time(s)
sheridan
Audio files: 27
PostPosted: Mon Jun 12, 2006 3:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Mmmm, sounds tasty... especially variation 4! Very Happy
transformer Sheridan
Hear music and Nord Modular G2 patches and find out music production tips at
http://www.nitetimeproductions.co.uk
Niio1
