the Digital/Analogue time bog
Post new topic   Reply to topic Moderators: paul e.
Page 5 of 6 [126 Posts]
Digital and Analogue together?
Totally
66%
 66%  [ 10 ]
Mostly
6%
 6%  [ 1 ]
A little bit
26%
 26%  [ 4 ]
No way
0%
 0%  [ 0 ]
Total Votes : 15
Audio files: 20
PostPosted: Wed Jun 14, 2006 8:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Which explains why some of us use Bias Peak for conversion.
Music at MySpace and Virb - Forum
Audio files: 20
PostPosted: Wed Jun 14, 2006 8:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Audio files: 20
PostPosted: Wed Jun 14, 2006 8:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Audio files: 20
PostPosted: Wed Jun 14, 2006 8:18 am    Post subject: Reply with quote  Mark this post and the followings unread
OK? I guess this kinda suggests there is a lot to the whole SRC thingie . Very Happy
More to be found all over the web. Tech books on SRC issues are recommended too.
Audio files: 20
PostPosted: Wed Jun 14, 2006 8:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Related , but not to SRC ( sample rate conversion ) , is how some of the vintage/warm/hyped analog gear really works and sounds like.
Universal Audio has some interesting stuff posted.
Like: The 1176 All Buttons Mode
cebec
G2 patch files: 31
PostPosted: Wed Jun 14, 2006 8:56 am    Post subject: Reply with quote  Mark this post and the followings unread
For Windows users there's Voxengo's r8brain SRC:
http://www.voxengo.com/product/r8brainpro/
Audio files: 88
PostPosted: Wed Jun 14, 2006 9:17 am    Post subject: Reply with quote  Mark this post and the followings unread
I found an SRC link that is for Secret Rabbit Code - a sample rate converter no less...
http://www.mega-nerd.com/SRC/
I got a good laugh readding about the All Buttons In compressor. Reminds me of the hype around the Joe Meek compressors which were designed by Ted Fletcher who presented at the Modular 2003 confernece in London. The latest incarnation of this is Edward, The Compressor. http://www.tfpro.com/products/info/13.php
Ted, BTW, is a facinating guy. Talk about stories...
Audio files: 20
PostPosted: Wed Jun 14, 2006 9:21 am    Post subject: Reply with quote  Mark this post and the followings unread
I have had Eddie here for some months and then some. It is great. The super low end turbo budget device .. the P4... is really nice too.
Audio files: 88
PostPosted: Wed Jun 14, 2006 9:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Back to SRC comparisons - this is an interesting site http://src.infinitewave.ca/
Kassen used the world startling when describing these results. That's a good choice. This is not rocket science - there is no excuse for a commercial DAW to include a noisy conversion program. Outrageous is another word that might be appropriate.
Audio files: 20
PostPosted: Wed Jun 14, 2006 9:23 am    Post subject: Reply with quote  Mark this post and the followings unread
FIY, the 1176 ABM can be truly useful at times.
cebec
G2 patch files: 31
PostPosted: Wed Jun 14, 2006 9:28 am    Post subject: Reply with quote  Mark this post and the followings unread
wow, that's great howard, thanks...
Audio files: 88
PostPosted: Wed Jun 14, 2006 9:40 am    Post subject: Reply with quote  Mark this post and the followings unread
It would be fun to have a room full of all of the compressors made.
Ted was big in the early 60s British pop productions where super high compression of vocals became cool. At his talk he played some of the earliest recordings to use these techniques. He is still in love with those sounds. It is an aquired taste, and after 45 years I still haven't aquired it - except maybe for The Beatles vocals.
PostPosted: Wed Jun 14, 2006 10:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmmmm, for realtime systems it's still not that easy. It seems obvious to use a FIR filter because here these are computationally efficient and they are phase-linear (asuming a symetrical filter) but this also means some samples of latency are added which may cause phasing issues when using multiple paralel tracks.
Is it already time to repeat my "you won't get perfection" remark again?
Audio files: 20
PostPosted: Wed Jun 14, 2006 10:51 am    Post subject: Reply with quote  Mark this post and the followings unread
I think so.
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Wed Jun 14, 2006 4:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, this is the second time I've made the wrong choice when it comes to resampling. First it was using Kontakt as my main sampler (see http://www.discodsp.com/highlife/aliasing/ - I now own and love Short Circuit), and now it's using Cubase to resample to 44.1k Laughing
I'll be downloading a copy of r8brain methinks. Thanks cebec, and mosc for that great link.
After doing a search for the Izotope SRC, I found a post on the Voxengo forums saying it's best to bounce to 32bit float, use your favourite limiter to shape the odd unwanted peak, convert to 16bit with your favourite dither/converter, then resample after that. This was at http://www.voxengo.com/forum/ar/1137/
Also, the paper that elekro's graphs are taken from is here: http://xserve1.bias-inc.com:16080/products/peakPro5/resampling/peakResamplingWhitePaper.pdf
Very interesting stuff.
cebec
G2 patch files: 31
PostPosted: Wed Jun 14, 2006 6:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
On dithering, since I came across this today as a result of this discussion -- there's a 'blind' dither shootout and the MegaBitMax Ultra algorithm, now in Izotope's Ozone 3 as MBIT+, has so far been determined as the most pleasing (quietest?) by a long shot.
http://www.24-96.net/dither/
The creator of that algorithm is now employed by Izotope, and is Alexey Lukin, the creator of Rightmark Audio Analyzer. There is a LOT of interesting technical info. here. Too bad the pics are gone, though.
http://audio.rightmark.org/lukin/dither/
I think I may try a combination of Ozone 3 for dithering and r8brain Pro for SRC and compare with my most recent method -- Sonar POW-R 3 for dithering and GoldWave's SRC, both of which have performed average or below average in all of the data I've seen so far. Rolling Eyes
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Wed Jun 14, 2006 7:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
For what it's worth, there seems to be a difference between a 96k file converted to 44.1k in Cubase and in r8brain free. It's subtle, and again in the top end. Some inharmonics are accentuated in the Cubase version... the r8brain one sounds more natural.
I was thinking about buying Ozone, purely for it's transparent eq and multi-band compressor for final mixdowns. Now knowing about the quality of it's dither algorithm, it looks alot more attractive. Especially at us$250 Cool
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Wed Jun 14, 2006 7:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Which pics? I can see the graphs etc. The audio files are there too Smile
cebec
G2 patch files: 31
PostPosted: Wed Jun 14, 2006 8:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
all the .pngs on this page are missing on my browser (Firefox 1.5.0.4)
http://audio.rightmark.org/lukin/dither/dither.htm
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Thu Jun 15, 2006 12:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Weird, they all show up here. I'm using Firefox 1.0.7 though.... They work in IE as well. Maybe you need a png library/dll or something? I don't remember installing one on this machine though.
cebec
G2 patch files: 31
PostPosted: Thu Jun 15, 2006 7:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Huh, yeah, that's weird. With this ver. of Firefox on two diff. machines, I'm unable to see those. Thanks!
Audio files: 88
PostPosted: Thu Jun 15, 2006 7:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cebec, me too. I can't see them and I'm using 1.5.0.4 Firefox too...
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Thu Jun 15, 2006 8:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Weird... I should really update my Firefox anyway, I'll see if I have the same problem.
Maybe have a look at forums.mozillazine.org ?
edit: Just updated my Firefox to 1.5.0.4, now I have the same problem. Still works in IE though.
Audio files: 20
PostPosted: Fri Jun 16, 2006 1:48 am    Post subject: Reply with quote  Mark this post and the followings unread
You guys cannot see the PNGs I posted as inline images above? Is that it?
Shocked
cebec
G2 patch files: 31
PostPosted: Fri Jun 16, 2006 4:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Nope, I'm referring to the one's on Alexey Lukin's page, linked above. I can see the ones here just fine. Hmmmmm...
