4 output panner
Page 1 of 1 [7 Posts]
and70it
PostPosted: Thu Jun 22, 2006 10:43 am    Post subject:  4 output panner
Subject description: quad
i need help ...
i'm searching to build a 4 out (quad) panner...
it's possible?
thanx
Audio files: 107
PostPosted: Thu Jun 22, 2006 12:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you use the forum's search function you'll get a lot more out of this site...
http://electro-music.com/forum/viewtopic.php?highlight=panner&t=10742
and70it
PostPosted: Thu Jun 29, 2006 12:27 am    Post subject: Reply with quote  Mark this post and the followings unread
ok this patch is very cool but my
problem is to rotate in real time my mono signal
in the 4 audio out by using a g2 knob.
Thanx
G2 patch files: 584
PostPosted: Thu Jun 29, 2006 12:54 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't have a quad setup but I think this works based on the 4-Out VU levels.
Is that sort of what you want?
Edit: not sure if the pan sounds better with the TriBell or CosBell setting on the LfoShp modules.
quadpanknob.pch2
1 knob quad pan
 Filename:  quadpanknob.pch2
 Filesize:  1.49 KB
 Downloaded:  647 Time(s)
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Thu Jun 29, 2006 11:38 am    Post subject: Reply with quote  Mark this post and the followings unread
I like it! All it needs is an overall volume (aka distance) control and we have the 1 in - 4 out panner we all saw in the first pic clavia released of the G2 editor.
thanks g2ian!
/Dasz
http://www.clavia.se/misc/users/daszgarncarz.htm
http://haagenlive.blogspot.com/
jksuperstar
G2 patch files: 18
PostPosted: Thu Jun 29, 2006 2:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thought this could be reduced down to 2 LFO's for wave shaping by using x-faders to do the panning. Order of rotation is 1-2-3-4, you'll notice the outputs from the cross faders are interleaved to match the LFO waveform phases. This puts the signal on 1-2 up front when the pot is straight up, and out the rear (3-4) when all left or all right.
I liked Ian's idea about the rst of the LFO's. I used 2-outs so this could be used in the demo, since my G2 is in the studio, not next to my laptop Smile
[edit- oops, just destroyed Jan's response when I edited this]
quadpanknob2.pch2
quad panner with less DSP
 Filename:  quadpanknob2.pch2
 Filesize:  1.25 KB
 Downloaded:  666 Time(s)
Audio files: 116
G2 patch files: 317
PostPosted: Thu Jun 29, 2006 2:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
jksuperstar wrote:
I liked Ian's idea about the rst of the LFO's, but I'm not sure if that forces them to be a zero freq. oscialltor,
When the dir input is zero the shape LFO's are stopped at their current phase position.
