DS 7 clone
Page 3 of 16 [383 Posts]
Goto page: Previous 1, 2, 3, 4, 5, ..., 14, 15, 16 Next
DiscoFreq
PostPosted: Fri Jul 21, 2006 1:56 am    Post subject: Reply with quote  Mark this post and the followings unread
I thought that information was on the site, but it seems it isn't, so I'll have to search Smile
I tried to trigger my drum synths with the CV outputs of my 80's Vermona DRM Drum Machine (not the DRM-1 Drum Synthesizer they make now). It has a 30-pin cable for separate audio outs for almost every sound and triggers for all sounds plus some extra triggers (16th notes and some triggers you can program on the Vermona). I can trigger all drum synths with the audio outputs, but only the Amdeks (and the Coron/Boss/Washburn Handclap modules) can be triggered with the triggers.
I will compare my trigger inputs with those of Marc Bareille. I discovered years ago that I could add such an input by connecting a jack on the wire between the Piezo cell and the Sens pot, but I see more components on the clones, so if you have no problems I should try to do something like that.
DiscoFreq
PostPosted: Fri Jul 21, 2006 1:57 am    Post subject: Reply with quote  Mark this post and the followings unread
zipzap wrote:
Cool site! never been there before. lots of stuff to check out and a nice collection of schematics (Böhm Trickverzerrer! i like that stuff)
Thanks for the comments Zipzap Smile
I have such a Trickverzerrer, it took me several months to find out what it was and with the schematics from Vermona.de I noticed it was not broken, but the Boss-type adaptor input (added by the previous owner) was wired inverse Smile
DiscoFreq
PostPosted: Fri Jul 21, 2006 3:20 am    Post subject: Reply with quote  Mark this post and the followings unread
I have no drawing of it by Marc Bareille (I suppose I made one myself, but I can't find it), but this is how he explained the CV mod to me:
Marc Bareille wrote:
To add a CV input to the DS7 ( vintage or clone...) is very simple.
You just need to add one resistor ( 33k to 100k) and one jack to the device.
One leg of the resistor is soldered to the Jack tip (hot point) , and the other leg of the resistor must be connected to the nodal point of R2,R9,R12,R13,U3 (refer to the DS7clone schematic on my website...)
DiscoFreq
PostPosted: Fri Jul 21, 2006 3:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh and for the Amdek PCK-100 (quite similar but with both sweep "up" AND "down" and multiple wave types for VCO and LFO) there's a lot of info (schematics, pcb, mods,...) on my site:
http://filters.muziq.be/model/amdek/pck100
It's the same as the Boss PC-2, this was a DIY kit version of it.
Audio files: 51
PostPosted: Fri Jul 21, 2006 4:25 am    Post subject: Reply with quote  Mark this post and the followings unread
The DiscoFreq is here! Very Happy
The DiscoFreq is here! Wink
Our forum has the coolest dudes! Cool
The DiscoFreq is here! Rolling Eyes
We would lose our friends.
So,.........
DiscoFreq
PostPosted: Fri Jul 21, 2006 6:21 am    Post subject: Reply with quote  Mark this post and the followings unread
OMG, I have fans! Wink
Scott Stites
Audio files: 96
PostPosted: Fri Jul 21, 2006 7:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Welcome indeed! Many a time I have cruised over to Disco Freq's site - lotsa good info!
Scott
dnny
PostPosted: Fri Jul 21, 2006 3:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
thats true!
maybe Thomas Henry will join someday Wink
www.koelse.org
flickr: cable porn group
dnny
PostPosted: Fri Jul 21, 2006 3:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
that's the spot right here:
but it shoud not trigger the envelope? diode D2 shoud prevent it right?
remember to use 0-5V CV because the whole unit runs on 5V... well that's what i think...
the whole schematic can be found here
www.koelse.org
Pehr
PostPosted: Sun Sep 24, 2006 11:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Is it really neccesary with log pots on the DS7? Confused
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
goodrevdoc
PostPosted: Sun Sep 24, 2006 1:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was wondering about this myself. Have not ordered pots as of yet, but i plan to build 4 in one box and have at least two with pink/white noise sources. From pouring endlessly over the schem, it doesn't seem so, save maybe for the output. Especially considering this is a drum synth, pitch and dialing in of sounds only has to be so accurate(at least for me anyway). I was also wondering if i could get away with just adding the output of a noise source directly to pin 3. Don't know if that counts as a VCA, but im hoping it will work, so as to keep my parts count down.
-justin
Pehr
PostPosted: Mon Sep 25, 2006 2:52 am    Post subject: Reply with quote  Mark this post and the followings unread
me too! Very Happy and I'm thinking about constructing a trigger sequencer somehow for them...
YouTube channel
flickr photostream
dnny
PostPosted: Mon Sep 25, 2006 10:35 am    Post subject: Reply with quote  Mark this post and the followings unread
no i don´t think so - well mine works nicely whit linear ones.
www.koelse.org
nisios
PostPosted: Mon Sep 25, 2006 11:04 am    Post subject: Reply with quote  Mark this post and the followings unread
I see a lot of people complaining about the ca3080.
I have a local shop here who has lots of these chips still. If its relly that important i can buy and send some.
Why is the dove a symbol of peace?
The pillow has a lot more feathers without that dangerous beak.
goodrevdoc
PostPosted: Mon Sep 25, 2006 12:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
How much/ how many nisois? CA3080's can still be had from places like eBay and futurlec, but if there be a deal I would certainly be interested.
nisios
PostPosted: Mon Sep 25, 2006 12:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
i need to go there and check that out.......last time i bought 8.....they had more....ill have to ask.....i think it was under 1 euro each.....not shure. I will pay them a visit this week and then i can tell you.
goodrevdoc
PostPosted: Mon Sep 25, 2006 5:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the tip, dnny. I had my suspicions as to the workability of log vs. lin. Now i will order lin pots and be done with it.
-justin
TheLegace
PostPosted: Wed Oct 04, 2006 8:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am so confused. Hey guyz I am newb DIYer.
I just dont understand what exactly the DS7 does, I have been looking on google and no info.
I know DS7 is a drum Synth, now it can be triggered to be connected to a Pezzio, do you have to sample a sound? How would you end up making one, for a complete drumset. With toms and everything.
Making multiple Dual DS7s and then having them connect through one output?
Any help is quite appreciated.
Audio files: 51
PostPosted: Wed Oct 04, 2006 9:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
It doesn't use samples, it's an analogue drum synth. That means it generates a tone and mixes that with noise and then it decays away like a drum would. It's a very electronic kind of drum sound.
Each DS7 is 1 drum, so for a full kit you would need multiple DS7s and a method to mix them together into 1 or 2 outputs.
So,.........
TheLegace
PostPosted: Thu Oct 05, 2006 4:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Ya I kinda figured that out now. Thank you, so you were saying it will make a very electric sound, can it make any acoustic type sounds, is there a way to preset it in a way to do it?
Audio files: 51
PostPosted: Thu Oct 05, 2006 5:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Negative.
So,.........
EraSer
PostPosted: Thu Oct 19, 2006 9:22 am    Post subject: Reply with quote  Mark this post and the followings unread
I would build DS7.I love how it sounds!But I have some question before building it
-capacitors are all electrolitics?
-Can you tell me the exact value of each capacitor?I don't find an exact correspondence between part list & schematic.For example:In the part list C1 is 10 uF and in the schematic C1 is 3u3?which is correct?
-I have CA324 & a HA17324 instead of LM324.Can I use them together?Or can I have problems with HA17324?
dnny
PostPosted: Fri Oct 20, 2006 3:55 am    Post subject: Reply with quote  Mark this post and the followings unread
not all C1,C2,C3,C6&C7 are.
Capacitors
1 C1 10uF/16V
2 C2,C3 3u3/16V
1 C4 47n
1 C5 1n
1 C6 0.1uF/16V
1 C7 1uF/16V
the part list is correct.
i would try the CA324 and if it´s not working... try to get a LM324 they are not so hard to find.
www.koelse.org
PostPosted: Fri Oct 20, 2006 11:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Right! This deserves to be a sticky too!!
Love the avatar Uncle K. Dunno what's more frightening, you or the teminator Shocked Laughing
ACHTUNG!
PostPosted: Fri Oct 20, 2006 11:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Embarassed
Oh dear- because of the alphabetical ordering, the DS7 has taken the place of King Klee. We cannot allow this!!! Exclamation Exclamation Exclamation
ACHTUNG!
