DiscoFreq
Posted: Fri Jul 21, 2006 1:56 am Post subject:
I thought that information was on the site, but it seems it isn't, so I'll have to search
I tried to trigger my drum synths with the CV outputs of my 80's Vermona DRM Drum Machine (not the DRM-1 Drum Synthesizer they make now). It has a 30-pin cable for separate audio outs for almost every sound and triggers for all sounds plus some extra triggers (16th notes and some triggers you can program on the Vermona). I can trigger all drum synths with the audio outputs, but only the Amdeks (and the Coron/Boss/Washburn Handclap modules) can be triggered with the triggers.
I will compare my trigger inputs with those of Marc Bareille. I discovered years ago that I could add such an input by connecting a jack on the wire between the Piezo cell and the Sens pot, but I see more components on the clones, so if you have no problems I should try to do something like that. |
DiscoFreq
Posted: Fri Jul 21, 2006 1:57 am Post subject:
| zipzap wrote: | | Cool site! never been there before. lots of stuff to check out and a nice collection of schematics (Böhm Trickverzerrer! i like that stuff) |
Thanks for the comments Zipzap
I have such a Trickverzerrer, it took me several months to find out what it was and with the schematics from Vermona.de I noticed it was not broken, but the Boss-type adaptor input (added by the previous owner) was wired inverse  |
DiscoFreq
Posted: Fri Jul 21, 2006 3:20 am Post subject:
I have no drawing of it by Marc Bareille (I suppose I made one myself, but I can't find it), but this is how he explained the CV mod to me:
| Marc Bareille wrote: | To add a CV input to the DS7 ( vintage or clone...) is very simple.
You just need to add one resistor ( 33k to 100k) and one jack to the device.
One leg of the resistor is soldered to the Jack tip (hot point) , and the other leg of the resistor must be connected to the nodal point of R2,R9,R12,R13,U3 (refer to the DS7clone schematic on my website...) |
DiscoFreq
Posted: Fri Jul 21, 2006 3:24 am Post subject:
Oh and for the Amdek PCK-100 (quite similar but with both sweep "up" AND "down" and multiple wave types for VCO and LFO) there's a lot of info (schematics, pcb, mods,...) on my site:
http://filters.muziq.be/model/amdek/pck100
It's the same as the Boss PC-2, this was a DIY kit version of it. |
Joined: Jul 11, 2005 Posts: 4742 Location: Nambucca Heads, Australia
Audio files: 51
Posted: Fri Jul 21, 2006 4:25 am Post subject:
The DiscoFreq is here!
Our forum has the coolest dudes!
The DiscoFreq is here!  _________________ If we thought and said hateful, discouraging, demeaning things to our friends,.....
We would lose our friends.
So,.........
Do you really want to lose yourself? |
DiscoFreq
Posted: Fri Jul 21, 2006 6:21 am Post subject:
| Uncle Krunkus wrote: | The DiscoFreq is here!
The DiscoFreq is here!  |
OMG, I have fans!  |
Scott Stites
Joined: Dec 23, 2005 Posts: 4119 Location: Mount Hope, KS USA
Audio files: 96
Posted: Fri Jul 21, 2006 7:24 am Post subject:
Welcome indeed! Many a time I have cruised over to Disco Freq's site - lotsa good info!
Scott |
dnny
Joined: Mar 12, 2005 Posts: 519 Location: Helsinki, Finland
Posted: Fri Jul 21, 2006 3:10 pm Post subject:
thats true!
maybe Thomas Henry will join someday  _________________ Association of experimental electronics
www.koelse.org
flickr: cable porn group |
dnny
Posted: Fri Jul 21, 2006 3:20 pm Post subject:
| DiscoFreq wrote: | I have no drawing of it by Marc Bareille (I suppose I made one myself, but I can't find it), but this is how he explained the CV mod to me:
that's the spot right here:
but it shoud not trigger the envelope? diode D2 shoud prevent it right?
remember to use 0-5V CV because the whole unit runs on 5V... well that's what i think...
the whole schematic can be found here _________________ Association of experimental electronics
www.koelse.org
Pehr
Joined: Aug 14, 2005 Posts: 1306 Location: Björkvik, Sweden
goodrevdoc
Joined: Sep 11, 2006 Posts: 288 Location: Philadelphia, PA
Posted: Sun Sep 24, 2006 1:21 pm Post subject:
| Quote: | | Is it really neccesary with log pots on the DS7? |
I was wondering about this myself. Have not ordered pots as of yet, but i plan to build 4 in one box and have at least two with pink/white noise sources. From pouring endlessly over the schem, it doesn't seem so, save maybe for the output. Especially considering this is a drum synth, pitch and dialing in of sounds only has to be so accurate(at least for me anyway). I was also wondering if i could get away with just adding the output of a noise source directly to pin 3. Don't know if that counts as a VCA, but im hoping it will work, so as to keep my parts count down.
-justin |
Pehr
dnny
Posted: Mon Sep 25, 2006 10:35 am Post subject:
| Pehr wrote: | Is it really neccesary with log pots on the DS7?  |
no i don´t think so - well mine works nicely whit linear ones. _________________ Association of experimental electronics
www.koelse.org
nisios
Joined: Sep 02, 2006 Posts: 43 Location: Braga - Portugal
Posted: Mon Sep 25, 2006 11:04 am Post subject:
I see a lot of people complaining about the ca3080.
I have a local shop here who has lots of these chips still. If its relly that important i can buy and send some. _________________ Why is the dove a symbol of peace?
The pillow has a lot more feathers without that dangerous beak. |
goodrevdoc
Posted: Mon Sep 25, 2006 12:07 pm Post subject:
| Quote: | I see a lot of people complaining about the ca3080.
I have a local shop here who has lots of these chips still. If its relly that important i can buy and send some. |
How much/ how many nisois? CA3080's can still be had from places like eBay and futurlec, but if there be a deal I would certainly be interested. |
nisios
Posted: Mon Sep 25, 2006 12:55 pm Post subject:
i need to go there and check that out.......last time i bought 8.....they had more....ill have to ask.....i think it was under 1 euro each.....not shure. I will pay them a visit this week and then i can tell you. _________________ Why is the dove a symbol of peace?
goodrevdoc
Posted: Mon Sep 25, 2006 5:32 pm Post subject:
Thanks for the tip, dnny. I had my suspicions as to the workability of log vs. lin. Now i will order lin pots and be done with it.
-justin |
TheLegace
Posted: Wed Oct 04, 2006 8:02 pm Post subject:
I am so confused. Hey guyz I am newb DIYer.
I just dont understand what exactly the DS7 does, I have been looking on google and no info.
I know DS7 is a drum Synth, now it can be triggered to be connected to a Pezzio, do you have to sample a sound? How would you end up making one, for a complete drumset. With toms and everything.
Making multiple Dual DS7s and then having them connect through one output?
Any help is quite appreciated. |
Audio files: 51
Posted: Wed Oct 04, 2006 9:00 pm Post subject:
It doesn't use samples, it's an analogue drum synth. That means it generates a tone and mixes that with noise and then it decays away like a drum would. It's a very electronic kind of drum sound.
Each DS7 is 1 drum, so for a full kit you would need multiple DS7s and a method to mix them together into 1 or 2 outputs. _________________ If we thought and said hateful, discouraging, demeaning things to our friends,.....
So,.........
TheLegace
Posted: Thu Oct 05, 2006 4:17 am Post subject:
| Uncle Krunkus wrote: | It doesn't use samples, it's an analogue drum synth. That means it generates a tone and mixes that with noise and then it decays away like a drum would. It's a very electronic kind of drum sound.
Each DS7 is 1 drum, so for a full kit you would need multiple DS7s and a method to mix them together into 1 or 2 outputs. |
Ya I kinda figured that out now. Thank you, so you were saying it will make a very electric sound, can it make any acoustic type sounds, is there a way to preset it in a way to do it? |
Audio files: 51
Posted: Thu Oct 05, 2006 5:20 am Post subject:
Negative. _________________ If we thought and said hateful, discouraging, demeaning things to our friends,.....
So,.........
EraSer
Posted: Thu Oct 19, 2006 9:22 am Post subject:
I would build DS7.I love how it sounds!But I have some question before building it
-capacitors are all electrolitics?
-Can you tell me the exact value of each capacitor?I don't find an exact correspondence between part list & schematic.For example:In the part list C1 is 10 uF and in the schematic C1 is 3u3?which is correct?
-I have CA324 & a HA17324 instead of LM324.Can I use them together?Or can I have problems with HA17324? |
dnny
Posted: Fri Oct 20, 2006 3:55 am Post subject:
| balance wrote: |
not all C1,C2,C3,C6&C7 are.
Capacitors
1 C1 10uF/16V
2 C2,C3 3u3/16V
1 C4 47n
1 C5 1n
1 C6 0.1uF/16V
1 C7 1uF/16V
the part list is correct.
| balance wrote: |
i would try the CA324 and if it´s not working... try to get a LM324 they are not so hard to find. _________________ Association of experimental electronics
www.koelse.org
Joined: May 16, 2005 Posts: 8905 Location: Birmingham, England, UK
Posted: Fri Oct 20, 2006 11:17 am Post subject:
Right! This deserves to be a sticky too!!
Love the avatar Uncle K. Dunno what's more frightening, you or the teminator  _________________ ACHTUNG!
Posted: Fri Oct 20, 2006 11:21 am Post subject:
Oh dear- because of the alphabetical ordering, the DS7 has taken the place of King Klee. We cannot allow this!!!  _________________ ACHTUNG!
