Oscilloscope
Page 1 of 1 [14 Posts]
mistercooper
PostPosted: Mon Jul 17, 2006 12:58 am    Post subject: Oscilloscope Reply with quote  Mark this post and the followings unread
Will a 10mhz oscilloscope do for sdiy work? Someone in the area is offering me one for $15.
Thanks,
Cooper
zipzap
PostPosted: Mon Jul 17, 2006 1:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Good Price. If it works fine than get it! Once you get into Pentium5diy you must get a new one. Then you can still hook the x-in to the left, the y to the right of your stereo and get hypnoticed.
mistercooper
PostPosted: Mon Jul 17, 2006 1:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Lol.
So it should be accurate enough for general sdiy circuits?
zipzap
PostPosted: Mon Jul 17, 2006 3:03 am    Post subject: Reply with quote  Mark this post and the followings unread
i guess so.
piedwagtail
PostPosted: Mon Jul 17, 2006 5:40 am    Post subject: Reply with quote  Mark this post and the followings unread
1 Mhz single channel i'll do fine:Reliability,sharpness and brightness are more important.
My Kenwood is dim and blurry but it suffices.
$15 is the price of two drinks in London..........
Robert
zipzap
PostPosted: Mon Jul 17, 2006 8:15 am    Post subject: Reply with quote  Mark this post and the followings unread
holy shit!
mistercooper
PostPosted: Tue Jul 18, 2006 6:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yay
I picked it up today and it works perfectly. Its a dual channel B+K. Now I just need to make myself a pair of BNC probes.
zipzap
PostPosted: Wed Jul 19, 2006 2:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Dual channal! you´re lucky. Bout the probes, i did nothing fancy, just the bnc plug+shielded guitar cable + alligator clip. That´s certainly not accurate, but it´s ok to see if you have a triangle or not and stuff like that.
If you mant to make good probes i think it goes like this: Take a 10meg resistor for a 1:10 probe. across that put a small adjustable cab (some pf i think). Connect the whole thing to something of what you know is a perfect square and adjust the cab untill u see a perfect square.
PostPosted: Thu Jul 20, 2006 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Actually to get 1/10 Vin (10:1 probe) at the vertical input amplifier of the scope, a series 9 MEG resistor would be required. The scope input impedance is typically 1 Mohm so 9/10 Vin would be across the 9 Mohm resistor and 1/10 Vin across the scope input. The load, unit under test, would see ideally 10 Mohm total impedance when probed.
Very Happy Very Happy Very Happy
zipzap
PostPosted: Thu Jul 20, 2006 1:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
you´re right
mistercooper
PostPosted: Thu Jul 20, 2006 2:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the info... would it be too much to ask for a diagram of what I should make? I bought a BNC->RCA adaptor so I can put whatever I need to at the end of some shielded cable now.
PostPosted: Fri Jul 21, 2006 7:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is a diagram of the equivalent 10X probe circuit. The equations will help you decide on circuit component values. The compensation capacitor is variable and should have the center of it's tuning range straddled in the center of the scopes time constant (C2 x R2) and have enough tuning range of 10 to 15 pF.
Hope this helps .......
 Filesize:  17.44 KB
 Viewed:  5459 Time(s)
mistercooper
PostPosted: Fri Jul 21, 2006 11:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you.
PostPosted: Fri Jul 21, 2006 12:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you.
Your welcome
