Crackles
Page 1 of 1 [4 Posts]
PostPosted: Sun Aug 06, 2006 9:27 am    Post subject: Crackles Reply with quote  Mark this post and the followings unread
A crackly sound. Was reading a discussion about Formant stuff here and wondered what would happen if you connected an audio-rate randomizer to the delay input. It so happened that this patch is more interesting if you keep the randomizer on a blue/yellow rate. A curious effect here (which i don't know if it has been discussed before) is that if you connect an oscillator output to the other inverter input (making the whole inverter orange) and then disconnect it again, the inverter stays orange. You have to delete it and drag in a new one to make it yellow.
/Stefan
sbt_crackles.pch2
 Filename:  sbt_crackles.pch2
 Filesize:  1.11 KB
 Downloaded:  1230 Time(s)
Audio files: 218
G2 patch files: 319
PostPosted: Sun Aug 06, 2006 9:53 am    Post subject: Re: Crackles Reply with quote  Mark this post and the followings unread
It's enough to "break the loop" actually, the orangeness is remembered because the inverters input turned orange, remove the input and it will go yellow again.
PostPosted: Sun Aug 06, 2006 10:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah! Thanks. Smile
/Stefan
Audio files: 218
G2 patch files: 319
PostPosted: Sun Aug 06, 2006 10:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice patch for making fire and rain like sounds !
