PCBs using a CNC Mill/Lathe (Front panels too!)
Page 1 of 1 [4 Posts]
shawn
PostPosted: Mon Aug 07, 2006 6:39 am    Post subject: PCBs using a CNC Mill/Lathe (Front panels too!) Reply with quote  Mark this post and the followings unread
I'll go ahead and start a topic on cnc lathe/milllers. My main reason to go with a cnc is in the past I've been using an XY Plotter drawing the pcbs. Then using a bubble tank, etch the pcb. This method is CHEAP but there's that whole dealing with chemicals problem. If someone wants to know how this is done, maybe I could start another topic using XT Plotters. I've done enough of it I could write a how-to.
To answer bugbrand's question, lead screws are basically a very long screw. You then have something that screws in it like a 'nut' but what it does is when you attach this nut to a item, when the lead screw rotates, it moves the item along the screw.
Here's a place that makes custom leadscrews:
http://kerkmotion.com/products/lead-screw/lead-screw.asp
Here's a photo of a lead screw:
A great resource in reading about this stuff is:
www.cnczone.com
Some examples of pcb's done with a cnc:
bugbrand
PostPosted: Mon Aug 07, 2006 8:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Supreme info! Thanks Shawn - much more to look into.
http://www.bugbrand.co.uk
bugbrand
PostPosted: Mon Aug 07, 2006 8:58 am    Post subject: Reply with quote  Mark this post and the followings unread
And just to add the links mentioned on this thread:::::
http://mikebeck.org/ -- Router Kit
http://www.hobbycnc.com/ -- controllers and stepper motors
bigtex
PostPosted: Mon Aug 07, 2006 10:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah, I see. It's a CNC router. Very nice. Very Happy The only other CNC router kit I have experience with is the ShopBot.
http://www.shopbottools.com/products.htm
They're big and expensive, but still cheaper than the full-size commercial equivalents that come completely built. Anyway... the ShopBot, even their "benchtop" model (which is too big for any bench I own) would be more than overkill for PCBs...
Thanks for starting this thread.
