audiopower depends on cpu load??
Page 1 of 1 [12 Posts]
W.T.
G2 patch files: 11
PostPosted: Sun Jul 02, 2006 11:04 am    Post subject:  audiopower depends on cpu load?? Reply with quote  Mark this post and the followings unread
i use an unexpanded g2 and recently found out that when i use a lot of dsp power in a peformance, lets say i use 3 slots for this, and use a fourth just for audio, a simple stereo flanger perhaps, the audio sounds very thin!
when i only use slot 4 with the audio patch, the sound is a lot thicker!! how does this come? is there also a sort of audio poly / bandwith depending on how much cpu is used? thanks in advance.
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Sun Jul 02, 2006 9:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Could you post the perf and/or wav recordings of the flanger with only 1 slot and 4 slots enabled?
3phase
G2 patch files: 138
PostPosted: Mon Jul 03, 2006 12:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
you have to look at the voice count of the slots..probably some of your patches get a reduced voice count when you enable a 4th slot and alter theire sound because of that
W.T.
G2 patch files: 11
PostPosted: Tue Jul 04, 2006 2:18 am    Post subject: Reply with quote  Mark this post and the followings unread
the problem is that it alters the audio path Confused
Fozzie
G2 patch files: 49
PostPosted: Tue Jul 04, 2006 2:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Is this internally generated audio routed through slot 4 or external-in audio? If it is the former, 3phase's suggestion might still apply. If it is the latter, well, that would be odd. Short sample for purpose of demonstration?
sheridan
Audio files: 27
PostPosted: Tue Jul 04, 2006 8:03 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm guessing it has something to do with polyphony/number of voices too... try using an FX area for your audio ins - you shouldn't hear any difference then (when you add other slots).
transformer Sheridan
W.T.
G2 patch files: 11
PostPosted: Sun Aug 13, 2006 9:23 am    Post subject: Reply with quote  Mark this post and the followings unread
it has something to do with that sheridan.
but still i ask way, every time i ad an voice the sound gets louder and louder.
very strange Shocked
in this next example you first hear a simple mono sawtooth modulated by hand that goes directly to the g2 output it sound like a nice sawtooth.
the second part of the mp3 is the same sawtooth but i know selected 32 voices, now it sounds more like the string osc....why is this??
it is the same single osc sawtooth but the sound sounds really different.
saw poly strange.mp3
 Filename:  saw poly strange.mp3
 Filesize:  343.17 KB
 Downloaded:  320 Time(s)
W.T.
G2 patch files: 11
it makes me feel like a noob Embarassed
Audio files: 116
G2 patch files: 317
PostPosted: Sun Aug 13, 2006 11:21 am    Post subject: Reply with quote  Mark this post and the followings unread
W.T. wrote:
it is the same single osc sawtooth .
Assuming you use no envelope after the osc, and that's what the mp3 sounds like :
No ... its not the same single osc but you have 32 of them, all with a different phase and all parellel and summed on the output. And that does two things, it smears out the shape and it will get louder.
In a patch using an envelope before the osc goes to the output it's different, as as you have to press a key first to hear the output. and you can't press the same key 32 times simultaneously.
Hope that helps explain it, but if not please say so.
W.T.
G2 patch files: 11
PostPosted: Sun Aug 13, 2006 2:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
this explains it really well.
But would this be some kind of bug or is there some logic behind it?
but now i know it doesn't bother me it actually sounds a bit cool Cool
thanks Jan
Audio files: 116
G2 patch files: 317
PostPosted: Sun Aug 13, 2006 2:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
It is not a bug, it is the working mechanism of the voices. Add a voice and the voice area gets duplicated (and so it needs DSP resources to be duplicated as well), but the FX area stays mono. All voice duplicates are automatically mixed in the output modules.
W.T.
G2 patch files: 11
PostPosted: Sun Aug 13, 2006 2:32 pm    Post subject:   Reply with quote  Mark this post and the followings unread
thanks
