circuit sculpture
Page 2 of 2 [35 Posts]
Goto page: Previous 1, 2
Audio files: 107
PostPosted: Sat Sep 02, 2006 11:20 am    Post subject: Reply with quote  Mark this post and the followings unread
The quality of that construction is fantastic. What a craftsman.
zipzap
PostPosted: Sat Sep 02, 2006 12:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes amazing.
He writes that he spent 7 years to design and build the machine.
http://www.myspace.com/lorolocoacousticpop
music and transcribed jazz basslines
zipzap
PostPosted: Wed Sep 06, 2006 12:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
I found another one. They say it´s working and playing music.
 Filesize:  69.91 KB
 Viewed:  94 Time(s)
Audio files: 107
PostPosted: Thu Sep 07, 2006 2:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yikes, that is shocking - I mean, the circuit has the potential to shock. Be very careful around tubes that have those little caps on the top. These are usually for the plate voltage - often quite high - several hundred volts. If you get across these points in the circuit and ground, you will certainly get a nasty shock - even a fatal one.
I would certainly keep a healthy distance from circuits that look like this.
Still, this looks cool... Cool
anttia
PostPosted: Thu Nov 23, 2006 1:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Insectshaped multivibrator
Olli Suorlahti from association of experimental electronics is working on the field of "circuit sculpture" as well. There is couple of pictures in our photopool in flicker:
http://www.flickr.com/photos/anttia/272115522/in/pool-21667895@N00/
http://www.flickr.com/photos/anttia/260515135/in/pool-21667895@N00/
http://www.flickr.com/photos/anttia/260515069/in/pool-21667895@N00/
http://www.flickr.com/photos/anttia/260443746/in/pool-21667895@N00/
zipzap
PostPosted: Thu Nov 23, 2006 5:07 am    Post subject: Reply with quote  Mark this post and the followings unread
very cool!
anttia
PostPosted: Thu Nov 23, 2006 8:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Have anybody heard of Peter Vogel? Seems to work on the same field as well.
http://www.weidigschule.de/galerie/vogel.htm
Joel
PostPosted: Thu Nov 23, 2006 10:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Yep, anybody who's read the first page of the thread Wink
worth pointing out though, his stuff is incredible!
Audio files: 107
PostPosted: Sun Nov 26, 2006 8:57 am    Post subject: Reply with quote  Mark this post and the followings unread
anttia - very nice stuff.
dnny
PostPosted: Tue Nov 28, 2006 12:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
also Freq Bands sculpture should be here, it's not circuit ,but it's made whit components i think it counts.
topic:Halloween
nice to see you here anttia
www.koelse.org
flickr: cable porn group
Niio1
