A harmless bug in the Tracking Generator
ThreeFingersOfLove
PostPosted: Mon Sep 11, 2006 4:31 am    Post subject: A harmless bug in the Tracking Generator Reply with quote  Mark this post and the followings unread
OK, this is a harmless bug I found in the Tracking Generator:
When you first select the TGen it shows 16 steps
1. Select only two steps
2. Select the second step and move it to the end of the range. (Far right)
3. Now, add a third step. It goes between the 1st and the last one. So when you select the steps in order it goes 1-3-2 instead of 1-2-3.
4. If you put 4 steps, the order is 1-3-4-2. The steps 3 and 4 are placed after the 2nd one only after you adjust their level.
This is not a big deal, but a bug nevertheless.
Niio2
