<on air> bingsatellites Mostly Ambient
 Forum index » Instruments and Equipment » Reaktor
Reaktor and Reason - compatible?
Page 1 of 1 [15 Posts]
Mr. Byagi
PostPosted: Thu Jun 08, 2006 6:24 pm    Post subject: Reaktor and Reason - compatible? Reply with quote  Mark this post and the followings unread
I've got reason on my computer and someone told me that I should look into reaktor. I like what I've seen, and I'm wondering how (or if) they can work together in any way. Is there something else I should be looking into getting to go along with reason instead of reaktor? If so, what is it?
Mohoyoho
PostPosted: Thu Jun 08, 2006 10:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't believe Reason allows any other instruments but its own. It does support Rewire, so it's possible to tie in via that. Reaktor is amazing. It's my favorite of the soft synths. I wish Reason would support VSTi's. It's my only complaint about it.
Mark Mahoney
Kingsport, Tennessee
www.cdbaby.com/cd/markmahoney
allofdrab
PostPosted: Thu Sep 21, 2006 11:15 am    Post subject: Re: Reaktor and Reason - compatible? Reply with quote  Mark this post and the followings unread
If it's Reaktor's modular environment that you like, I suggest you ReWire Reason to Bidule, see how you like it.
Aside from Bidule's built in audio, MIDI and spectral processing capabilites, it also functions as a VST/VSTi plugin host, which allows you to blow your mind looking at all the plugins available.
http://www.plogue.com/forums.html?option=content&task=view&id=21&Itemid=35
Note: Bidule is at the end of a beta cycle, so you may have to wait a some days for the latest version to be released to non-registered users.
allofdrab
PostPosted: Thu Sep 21, 2006 11:31 am    Post subject: Re: Reaktor and Reason - compatible? Reply with quote  Mark this post and the followings unread
Not sure how much you're ready to tackle,
but Max/MSP is another ReWire option that may suit your tastes.
http://www.cycling74.com/products/maxmsp
Max/MSP ReWire tutorial:
http://www.cycling74.com/story/2006/9/18/121516/485
ReaktorFreak
PostPosted: Sat Oct 06, 2007 9:04 am    Post subject: Reply with quote  Mark this post and the followings unread
I think the best way is using Cubase SX / Nuendo as a host and use Reaktor as Vsti while opening Reason as a ReWire Slave. I've used both programs that way and everything's going well.
spacetimegod
PostPosted: Fri Sep 05, 2008 5:43 am    Post subject: Reply with quote  Mark this post and the followings unread
If you are using REASON at all you must, I repeat Must, have an Alternate DAW, Such as Pro-tools Or Logic. Reason is a brilliant program but the sound engine is complete crap. Re-wire through another Program and you lose the "Reasony" sound. Plus you can use plug-ins such as Reaktor.
ReaktorFreak
PostPosted: Wed Sep 10, 2008 8:16 am    Post subject: Reply with quote  Mark this post and the followings unread
I thought the sound engine quality through Rewire is determined by the audio card, i've never knew that the DAW also played a role in sound quality.. i'd really like to know more about it.
ew
PostPosted: Sun Oct 26, 2008 12:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
The soundcard has absolutely nothing to do with sound quality in a DAW unless you're recording external audio. All the soundcard's used for is getting audio in and out of the computer.
With virtual instruments you're monitoring through the soundcard, and not recording through it. There's a big difference...
ew
ReaktorFreak
PostPosted: Wed Oct 29, 2008 8:41 am    Post subject: Reply with quote  Mark this post and the followings unread
ew
So how the sound of a particular softsynth is going to be is determined by the host as well since the host is doing the audio rendering in Rewire i assume..
ew
PostPosted: Wed Oct 29, 2008 10:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Besides panning laws, there isn't really any difference between the rendered audio with any host, if you're using the same sample rate/bit depth. It's all 1s and 0s, after all.
The only other place you might see a difference is due to internal resolution- the higher the resolution, the more headroom you have. However, render the same track with two different DAWs; I'm betting you won't hear any difference.
The main differences in DAWs these days are workflow related, what bundled plugins they come with and/or compatibility with third party plugins. Anything else for the most part is just smoke and mirrors.
ew
ReaktorFreak
PostPosted: Wed Oct 29, 2008 9:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Now i'm getting really confused.. i have some people telling me that protools mix sounded better than nuendo, and from this :
i thought it means that Rewiring Reason to different DAW produces different result on the audio, and also different from the one that rendered within Reason itself. Guess i was wrong then.
ew
PostPosted: Wed Oct 29, 2008 10:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you want to believe that, fine. I've heard amazing music done entirely in Reason and absolute crap done in PT HD/Nuendo/what have you.
It all comes down to the artist and which tools he/she feels comfortable with. If you don't have Reason, download the demo and listen to it on its own and ReWired into your host of choice. Hear any difference?
ew
ReaktorFreak
PostPosted: Wed Oct 29, 2008 11:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm crap at distinguishing audio quality.. thanks for convincing me that the myth is not true, it's been bugging me for a long time.
mtvic
PostPosted: Thu Oct 30, 2008 3:35 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome ew
welcome
are you ew from NI Forums?
ew
PostPosted: Thu Oct 30, 2008 8:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the welcome. And yep, that's me.
ew
AmbiphonicDSP
