  bingsatellites Mostly Ambient
 Forum index » Clavia Nord Modular » G2 Patches - Completed » Lead
Benny Benassi - Satisfaction
Page 1 of 1 [9 Posts]
Wind
PostPosted: Sat May 27, 2006 1:43 pm    Post subject: Benny Benassi - Satisfaction
Subject description: Benassi's trademark lead sound
This is my effort to emulate Benny Benassi's sound in the song
"Satisfaction". As always, Mod. Wheel controls filters (HPF used here).
Benassi.pch2
Benassi Lead
 Filename:  Benassi.pch2
 Filesize:  1.46 KB
 Downloaded:  1195 Time(s)
http://www.jmelas.gr
Tranceparent
PostPosted: Sun May 28, 2006 5:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Well done Wind! Thanks!!! Cool
*I modified Wind's patch a bit so that it reaches my point of view... Wink
benassi_152 (Modified).pch2
Satisfactionism...
 Filename:  benassi_152 (Modified).pch2
 Filesize:  1.82 KB
 Downloaded:  975 Time(s)
Clavia Nord Modular G2X rules!
Moduled Modulated Modulation Modular Module...
Tranceparent
PostPosted: Mon May 29, 2006 2:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Any comments/adds anyone please? They'll all be welcome! Wink
G2 patch files: 584
PostPosted: Mon May 29, 2006 3:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
I had to google to find out who benny benassi was Embarassed
After watching the video Embarassed Embarassed
I think your patch is very close. The song has some variation where a 2nd VCO is added. My guess is its a MS20 but the G2 is quite good at emulating an MS20.
selvmarcus
G2 patch files: 39
PostPosted: Mon May 29, 2006 4:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
No, it isn´t. I had an MS20, once. No comparison, IMO. It´s analog.
Not to say it´s better, just different sound. To get analog sound is
not impossible on a digital, but much more work usually.
But on a real analog, (almost) every sound *does* "sound analog". Smile
Anyway, I like the G2! And I miss my MS20 and Mono/Poly, too...
Greetings,
Marcus
Something with this universe is somehow perfectly sound and in order.
G2 patch files: 584
PostPosted: Mon May 29, 2006 4:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
You might be right, maybe I should have another 'listen' Embarassed to the video.
I had an MS20 as well, sold it in Bondi Junction in 1979. Dont miss it at all.
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Tue May 30, 2006 1:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Alot of his sound comes down to the high grade compressor he uses side chained to the kick and also his reverb module/plugin. I think you could use any half decent saw and very close to the same effect, mainly because what gives it it's identifiable character is how the compression and reverb interact with it. This has probably been EQ'd to sound fatter, maybe run through some slight saturation effect. And then there's the mastering etc.
I think you've done a really good job of getting his saw lead/bass sound, but I don't think you're ever going to get it exact unless you had his gear in front of you. And even then, I think we'd all be hard pressed to do exactly what he did, and even more so what his highly paid engineer and mastering engineer did.
selvmarcus
G2 patch files: 39
PostPosted: Tue May 30, 2006 10:54 am    Post subject: Reply with quote  Mark this post and the followings unread
MS20...
I used to plug it into a tape echo followed by a leslie type rotating speaker
(running in slow mode) with added spring-reverb.
Then I plugged a microphone into the EXT SIG input, and gave me 2 pitch
following OSCs and some filtered voice mixed in too...
Feedback could happen then, with the pitch follower going mad, which was very welcome!
And then there´s been my famous "vulcano explosion and hot bubbling mud"
patch, I never got this again anywhere else Sad
Maybe that´s where these special memories are coming from,
because yes I was dissappointed with it´s basic (lead) sound first.
I think I was 15 or 17.
Marcus
MitchK1989
PostPosted: Sun Oct 01, 2006 7:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
I haven't gotten a nord modular yet to test out this sound on... But the benni bennassi HPF sound in satisfaction comes from a virus C... Not an MS-20.
Niio2
