  Muied Lumens Frequencies
External gate problem
Page 1 of 1 [3 Posts]
prgdeltablues
Audio files: 12
PostPosted: Mon Sep 25, 2006 5:03 am    Post subject: External gate problem Reply with quote  Mark this post and the followings unread
Hi, new to the forum, just built my Soundlab over the summer. Working fine, needs a few knobs and I'll then get round to posting a picture. Brilliant machine. A couple of problems though.
I'm prototyping a ribbon controller for it, based on the stripboard resistor ladder which I saw described on this forum, and then using the second part of the circuit from the guitar trigger to provide a gate out. So the circuit basically goes : raw cv voltage -> op amp buffer -> cv out at this point -> diode, etc into op-amp comparator (without hysteresis) for gate out. Hope that makes sense.
Breadboarded using 741s, and the cv works fine. With the AR mode switch set to Trigger, it also all works fine - Frequency controlled by the external cv, Attack and Decay times controlled by those two pots on the soundlab. But with the mode set to Gate, I still get an Attack time, but no Decay time - just abrupt end when I release the switch and the raw cv voltage goes to 0. Guess I'll have to open the case up and check the wiring, but if anyone has any thoughts that would be great.
A second problem. Swapped the 741 over for a TL072 for both op-amp positions), and now instead of a clean end to the output, when I disconnect the raw cv voltage, the frequency decays irregularly down over about 1/2 second, then there's another 1/2 before a small click, and only then can a new note be started. It's actually a rather interesting effect, bit chorusy, but not one I was looking for. Has anyone else encountered this, with different op-amps - and does anyone have an explanation!
Thanks to Ray for a wonderful synth project and helpful website.
Peter
prgdeltablues
Audio files: 12
PostPosted: Mon Oct 02, 2006 9:36 am    Post subject: External gate problem Reply with quote  Mark this post and the followings unread
A follow-up. Worked out over the weekend that the reason there's no release time is that my external AR voltage is driven by the CV voltage. CV goes to 0 means AR drops to 0 too. Duh! Set up an independent gate voltage and it works fine. But the circuit still isn't happy with a TL072. Works OK with 741's. Going to get a bunch of other op-amps and try them out.
Peter
Wild Zebra
PostPosted: Mon Oct 02, 2006 12:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool glad you got it going. Looking forward to some pics.
"your stripes are killer bro"
