richardnixon
Joined: Feb 08, 2006 Posts: 35 Location: Campbell, CA
G2 patch files: 4
Gordon Charlton
Posted: Sat Oct 07, 2006 1:02 am Post subject:
I'm a thereminist seriously considering getting a G2 engine with the specific intention of driving it with my moog etherwave.
Could you comment on how well the pitch and amplitude tracking work with your patch?
Ideally, would it be possible to provide an audio file with the audio output of the theremin on the left, and the output of your patch on the right, please?
Also could you take a screen snapshot of the patch please, as I would like to see what it looks like but cannot load it into the demo software.
Thank you. |
Joined: Apr 03, 2004 Posts: 24085 Location: The Netherlands, Enschede
Audio files: 278
Posted: Sat Oct 07, 2006 3:43 am Post subject:
Welcome Gordon.
To see the patch you could download the real editor at http://www.clavia.se/products/nordmodular/software.htm and open the patch in that one. It will not play the patch then of course, without the hardware.
When you install it you might want to not let it take the pch2 file extension, so that by default patches will still open in the demo software. _________________ Jan
Gordon Charlton
Posted: Sat Oct 07, 2006 1:19 pm Post subject:
Jan, that was a very helpful suggestion. Thanks.
And richardnixon, if you're still around, that's a lovely patch - I'm a complete beginner, but I can see how it works and it looks like an ideal starting point for when my finances allow me to actually buy a Nord. In fact it looks like a good patch to take with me to a shop along with my etherwave for a test drive.
Audio files: 278
Posted: Sun Oct 08, 2006 3:25 pm Post subject:
Gordon, there might even live some helpful g2 owning forum member near you, but you'd have to be a bit more specific on your location then I guess _________________ Jan
Gordon Charlton
Posted: Sun Oct 08, 2006 3:57 pm Post subject:
I'm sitting on the sofa by the window in the living room.
Is that specific enough?
Oh.
Er.
Ah, I see.
Near Watford, Herts. I've put the kettle on. |
Audio files: 278
Posted: Sun Oct 08, 2006 4:16 pm Post subject:
richardnixon
G2 patch files: 4
Posted: Mon Oct 09, 2006 11:14 am Post subject:
Hi Gordon,
The pitch tracking on the G2 works extremely well, much better than I had thought it would. I do sometimes get a bit of what sounds like hi-freq aliasing when the theremin's pitch is near zero beat, however, since one rarely actually plays at that frequency, other than for effect, it isn't a bother. There can also be some odd noises when you go from barely touching the pitch antenna to actually touching it. Again, this isn't done very often so it doesn't become a problem (although we did use this sound on a friends record as an effect with great results!) Also, as I mentioned in the original post, set both the waveform and brightness controls fully counter-clockwise for the best tracking results.
The Amplitude tracking is also spot on, it's very responsive, almost exactly like the unprocessed theremin.
The autotune section is a bit of a joke and not very useful. There is a glide module to make the transitions between "quantized" notes a bit less abrupt, but that only helps so much. It's original intention was to be able to also convert the pitch tracked theremin to a MIDI signal (which would obviously have to be quantized to specific MIDI notes + pitchbend), but that didn't work out either.
The patch certainly does allow for some great tonal variations with the theremin. You can't help but smile when doing a long glissando and sweeping the filter with a foot pedal _________________ ...if the computer will not startup, something else is wrong with the computer... |
Gordon Charlton
Posted: Mon Oct 09, 2006 12:35 pm Post subject:
richardnixon wrote: | Hi Gordon,
The patch certainly does allow for some great tonal variations with the theremin. |
That's very encouraging to hear. I wasn't looking forward to spending extra money just to get the audio output into CV, or having someone do the outrageously complicated mod in the hotrodding manual. It brings my owning a red slab just that bit closer. :-)
(Incidentally, did you know there are a couple of dedicated Theremin to CV/MIDI converters available that do all the pitch-bendy stuff for MIDI. Here, in the US and here in the UK.) |
richardnixon
G2 patch files: 4
Posted: Mon Oct 09, 2006 2:57 pm Post subject:
Gordon Charlton wrote: | richardnixon wrote: | Hi Gordon,
I felt the same way, and with the power that the G2 has, I figured I might be able to do it. I probably could, but would require more time than I was willing to devote to it.
I am now debating the attempt at modding the etherwave for pitch CV (volume CV is pretty easy) so I can control my recently purchased voyager. Either that or save up for the Etherwave pro. _________________ ...if the computer will not startup, something else is wrong with the computer... |
Gordon Charlton
Posted: Sat Oct 14, 2006 2:17 am Post subject:
Excuse me while I air my ignorance for a moment.
My first thought was - well you could use the nord to do the audio->CV, but I noticed it doesn't have CV out.
But then I noticed the demo lets you connect CV lines to the audio out. I didn't post this because I realised CV out and audio out were at different levels etc. so not compatible.
Then I saw a link to this: http://synthesizers.com/q125.html in a posting over on thereminworld.com so now I'm wondering if you could use the nord to do the conversion and send the result to its audio outs, then tweak the audio outs of the nord so they fitted the CV ins on your voyager.
Probably there's some good tech reason why not, but it's a thought. |
varice
Joined: Dec 29, 2004 Posts: 961 Location: Northeastern shore of Toledo Bend
Audio files: 29
G2 patch files: 54
Posted: Sat Oct 14, 2006 11:33 am Post subject:
Gordon Charlton wrote: | ...I'm wondering if you could use the nord to do the conversion and send the result to its audio outs, then tweak the audio outs of the nord so they fitted the CV ins on your voyager.
The G2 has DC blocking capacitors on the audio outputs which prevent DC control voltages from being present at the output jacks. I modified my G2X to get a CV output for my moogerfooger LPF. Check this out:
http://electro-music.com/forum/topic-12266.html _________________ varice |
