Potentiometer wattage concern
Page 1 of 1 [2 Posts]
numbernone
PostPosted: Fri Oct 06, 2006 9:21 am    Post subject: Potentiometer wattage concern Reply with quote  Mark this post and the followings unread
So I am aiming to cram alot into a small space on the next soundlab, the pots that I have specified are on .1watt, while the official parts list specifies .5w pots. What are the dangers involved in an insufficient rating? Cant seem to find ANY mini pots above .1W...
Thanks plenty.
PostPosted: Sat Oct 07, 2006 8:05 am    Post subject: Reply with quote  Mark this post and the followings unread
I doubt very much that there would be any danger in using .1W pots because the SL uses so little power anyway, and almost every pot on it has a 100K resistor on the wiper. There are some basic investigations you can do to be sure, but I wouldn't bother. What's the worst that's gonna happen? One of them might get a bit warm or start to smoke at one end of it's travel. If it did, replace it and add a bit of insurance.
You won't find tiny pots with much of a power rating anywhere. It flies in the face of a basic electronics truth. Higher power means larger size. Which is true of every electronics component I know of.
