 FAQFAQ   CalendarCalendar   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   LinksLinks GalleryGallery
timer class
Page 1 of 1 [4 Posts]
moudi
PostPosted: Fri Oct 13, 2006 12:46 pm    Post subject: timer class Reply with quote  Mark this post and the followings unread
hi all
i just started with ChucK (i use it with miniAudicle) and tried to write a little timer class for the syncronisation.
I get some problems when i use it, so i would like to ask you some (probably stupid Confused ) questions.
this is the class i wrote:
public class timer
int beats;
float bpm;
dur beat;
dur bar;
fun void set(int _beats, float _bpm)
_beats => beats;
_bpm => bpm;
(60 / bpm)::second => beat;
beats::beat => bar;
fun dur wait()
return (bar - (now % bar));
1: is it possible to automatically load a class with the startup of the virtual machine?
I assume that i will have to compile ChucK myself with the new class included, but is it also somehow possible with miniAudicle? (i didn't found any sources, i assume miniAudicle is not open source?).
2: the function timer.wait should return a duration value, but is indicated as 'function' if i print it. therefore it's not possible to use it for timing (e.g. chucking to "now").
3: the timer.wait returns allways the same value. it looks like, that the keyword "now" stays as a fixed value (probably the time the class was loaded?).
many thx in advance for some replies
regards
/moudi
by the way: ChucK RULES Very Happy
spencer
PostPosted: Sun Oct 15, 2006 2:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey there moudi,
Presently, this is not possible without changing the source code, although we could probably implement that feature if you think it would be a useful feature.
This approach is possible, but you would probably want to do it a special way. All of ChucK's built-in classes are implemented in C++, but it would probably be a lot easier in your case to automatically add shreds from hard coded ChucK source or filenames when ChucK/the VM is started.
miniAudicle is totally open source! but I guess we don't make that very clear. The only direct link to the source is on the Linux miniAudicle ("liniAudicle") page, but the source distribution includes sources for all 3 platforms. here it is:
http://audicle.cs.princeton.edu/mini/release/files/miniAudicle-0.1.3.6.tgz
Hmm, how are you printing/calling the function? I tried running your code as you said, and timer.wait correctly returns a dur. Are you calling it like this?
Code:
<<< timer.wait() >>>;
If you leave the parentheses out, then it is a function, but with the parentheses it will evaluate to a dur.
Again, are you including parentheses in your function call?
Code:
timer.wait
will always return the same thing, but
Code:
timer.wait()
should not...
no argument here!
hope this helps,
spencer
moudi
PostPosted: Mon Oct 16, 2006 2:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi spencer
thank you for your answers. things get a lot clearer now..
For me it will be very useful. Are there already other existing wishes in this direction, or am i the only one? I mean, it makes no sense to implement something for only one person... but it would be definitely great.
cool. thx for this link. i will have a look at it in the near future.
atm i'm very busy with learning the basics in ChucK Wink
it will become more important when i'm more familiar with it.
Code:
<<<timer>>>;
Gosh! Embarassed i forgot the parentheses! SILLY ME!
since i work with automatic completion in .net i never thought about this... Rolling Eyes
great to have you guys here
/moudi
spencer
PostPosted: Thu Oct 19, 2006 2:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think you're the only one so far, but it's definitely a feature that makes a lot of sense, and has some precedence in command line chuck. Ill run the idea by some other folks, and maybe see about working that into an upcoming release.
thanks!
spencer
Once You Know, You Newegg
Copyright © 2003, 2004, 2005, 2006 and 2007 by electro-music.com
