 Forum index » Clavia Nord Modular » Bugs
Help me - midi out
Page 1 of 1 [12 Posts]
JLS
G2 patch files: 316
PostPosted: Sat Oct 14, 2006 3:48 am    Post subject: Help me - midi out Reply with quote  Mark this post and the followings unread
Hi all
please help me
my G2 not transmit AfterTouch and PitchWheel to Midi Out !!!!
arpegiator, note, velocity and controller working fine
very thanks
sorry my bad english ( please patch example )
Audio files: 278
PostPosted: Sat Oct 14, 2006 6:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Just a guess can't really find it in the manual, but maybe in "synth settings" sending controllers is off ? Well its the closest thing I could find.
JLS
G2 patch files: 316
PostPosted: Sat Oct 14, 2006 9:55 am    Post subject: Reply with quote  Mark this post and the followings unread
This function not implemented in OS
Transmit only controllers, note, velocity, arpegio, midi clock
After touch and pitch wheel not controllers, this is extended midi parameter
New typ for Clavia developer OS 1.5
- update this very big bug Smile
Audio files: 213
PostPosted: Sat Oct 14, 2006 10:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Moving this to the bug list.
davep
Audio files: 10
G2 patch files: 73
PostPosted: Thu Oct 19, 2006 3:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
My G2 transmits the pitch stick data OK, no problem here.
Regarding the aftertouch, I use it in an unusual way, but this may help you too:
I like to add some slewing to the aftertouch response so it has a longer decay after you release the note. This is more musical on patches that have a long release, so the aftertouch doesn't suddenly shut off while the note is still decaying. To do this, I use the "DEVICE" module in a patch to access the aftertouch signal, and then patch this signal through an envelope follower. I then patch the EnvFol output to a Midi Send module and assign the processed aftertouch signal to a cc#.
If you can't get the aftertouch to work in the normal way, you could use this method of using the DEVICE module and re-assigning the aftertouch signal to a cc# and set the receiving device to use this same cc#.
Dave Peck
JLS
G2 patch files: 316
PostPosted: Fri Oct 20, 2006 5:33 am    Post subject: Reply with quote  Mark this post and the followings unread
im not use G2 but G2 engine
master key Kawai K1-II
Kawai ---- PC working PitchBend and AT OK
Kawai ---- G2engine -----PC not transmited
if use G2engine like midi processor
( other controllers working OK )
davep
Audio files: 10
G2 patch files: 73
PostPosted: Fri Oct 20, 2006 12:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
So you mean Pitchbend and AT from the Kawai is going into the Engine, but is not coming back out? Maybe I do not understand, but it sounds like maybe you should be using the midi THRU connector on the Engine, not the midi OUT connector?
Dave Peck
JLS
G2 patch files: 316
PostPosted: Fri Oct 20, 2006 12:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
im using midiout connector not miditrue
miditrue only send direct event from master key ( midi in )
if connect miditrue data transmited ok but not G2 midi processed
if connect midiout data transmited ok but not transmited Pitch Bend and AT
davep
Audio files: 10
G2 patch files: 73
PostPosted: Fri Oct 20, 2006 1:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah, I understand. That IS a problem. And the idea of the midi modules could not be used because those will only access the pitch bend & AT data that is generated inside the G2, not from something connected to the midi in, and the Engine does not generate these signals.
If this really is a bug and the G2 is losing the data that is coming in, then maybe there is a way to use a simple midi merge box to combine the pitchbend & AT from the Kawai with the final processed midi from the G2? I know it is clumsy, but maybe it would work. Wow, that is a major bug.
Dave Peck
Audio files: 278
PostPosted: Fri Oct 20, 2006 2:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not so simple I guess, at least in general, unless the merger could be made to filter certain data.
It really makes the G2 less useful as a MIDI processor.
JLS
G2 patch files: 316
PostPosted: Fri Oct 20, 2006 2:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
im use my creamware card like merge box and filter some midi event ( creamware midi merge module and midi filter )
Idea for new G2 module
midi merger module
midi filter module
sysex register in/out module
what new info about new G2 OS ?
Audio files: 278
PostPosted: Fri Oct 20, 2006 3:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nothing I'm affraid ...
