Coriolis
Joined: Apr 11, 2005 Posts: 616 Location: Stilling, Denmark
Posted: Wed Sep 27, 2006 12:16 pm Post subject:
Korg triple resonator schematics? Subject description: Didn't someone here have them? Scott Stites? |
Benn trying to find the schems for these - supposedly they are on Jürgen Haibles site, but I can't find them there!
Anybody got them?
C |
Scott Stites
Audio files: 96
Posted: Wed Sep 27, 2006 1:18 pm Post subject:
I've got'em somewhere. If you go through JH's PS3100 clone, you'll find a modified version of it that he did, which no doubt sounds absolutely out of this world. But, I'll check my archives - I still have it on breadboard, as a matter of fact (very, very sweet function).
Scott |
yusynth
Coriolis
Posted: Thu Sep 28, 2006 2:30 am Post subject:
Thanks Yves!
I trawled through Jürgens pages on the PS3100, but all I could find (that I could partially understand) was this:. But where is the filter core?
I would like to see what he's done with it, but then again, the circuit looks so simple, even I could probably breadboard it!
I assume those vactrols are VTL5C3/2 types? Or is there some sort of mojo in having 2 separate LED's shine on 2 separate photocells (relating to, say, a diode drop between the 2 LED's in series)?
C |
yusynth
Coriolis
Posted: Thu Sep 28, 2006 3:43 am Post subject:
Hmm, yes I suppose Babelfish helps a bit.
One thing is a bit unclear to me though: is it the filter resonance that is under cv-control, or the frequency? I don't see a frequncy control anywhere, so it would appear that those are preset values...
C |
yusynth
Posted: Thu Sep 28, 2006 4:53 am Post subject:
No, it's the frequencies of the three cells that are under CV, the resonance of these filters is fixed (and is around Q=5).
If you look at the schematic ps-3100-res-2.gif from RJB, you have three pots called 1st peak, 2nd peak and 3rd peak. These let you set the central frequency of each filter. Then a CV applied either to point 7 or 8 or ps-3100-res-2.gif let you modulate the frequencies of all filters.
If you wish you can add also a separate CV for each filter by adding a separate input resistors at the bases of Q102,Q103 and Q104. _________________ Yves |
Scott Stites
Audio files: 96
Posted: Thu Sep 28, 2006 6:09 am Post subject:
Quote: | If you wish you can add also a separate CV for each filter by adding a separate input resistors at the bases of Q102,Q103 and Q104. |
I highly recommend this, too - it really adds a lot to the function of the resonator. JH took real advantage of this, and, if I'm not mistaken, was instrumental in the development of the MAM RS3, which is based on the resonator circuit. To get an idea of the effect that can have, read this:
http://www.midiwall.com/gear/rs3.html
Scott |
Coriolis
Posted: Thu Sep 28, 2006 12:26 pm Post subject:
Ah, I'm slowly getting the picture...
Think I heard an RS3 demo on the MAM website once - very nice!
I see JH uses 5C4/2's for vactrols.
This is now on my todo list!
Thanks guys!
C |
Scott Stites
Audio files: 96
Posted: Thu Sep 28, 2006 2:16 pm Post subject:
First time I ever heard one was on Jeff Pontius' SynthImagery album. I emailed him and asked him what kind of crazy phase shifter he had - he replied that it wasn't a phase shifter, but was in fact the RS3. Later, the first time I visited him, he let me play his Prophet 5 through it - I literally went weak in the knees, it sounded *that* good.
Scott |
sneakthief
Posted: Mon Oct 02, 2006 6:19 am Post subject:
Coriolis wrote: | I trawled through Jürgens pages on the PS3100, but all I could find (that I could partially understand) was this:. But where is the filter core?
Hi Coriolis - The filter core is here in the middle: http://jhaible.heim.at/polykorg/jh_3200_signal_1of4.gif
Jurgen used VTL5C4/2's, while if I'm not mistaken, Scott used VTL5C3/2's.
I was planning on building this for a couple of months now and am about to order the parts for it
What I'm wondering is which one will sound better for this application:
michell _________________ Sneak-Thief - raw electrofunk |
Coriolis
Posted: Tue Oct 10, 2006 10:15 am Post subject:
Ah, thanks for pointing that out to me!
I saw the vactrols, but not the opamps I thought were supposed to be there.
I guess JH used discretes instead.
Vactrols:
If I understand those numbers correctly, then the 5C4/2 is a lot slower to turn on and off, than the 5C3/2, yes?
Which would give a more sluggish, "muddy" sound, I guess.
Don't know if that's desirable in this case, but then JH used them, so...
C |
sneakthief
Posted: Tue Oct 10, 2006 11:25 am Post subject:
scott told me he used vtl5c3/2's and they sounded great. after perusing all of the schematics, that seems to be a good enough answer for me _________________ Sneak-Thief - raw electrofunk |
Coriolis
Posted: Tue Oct 10, 2006 9:06 pm Post subject:
I agree. Also, they seem to be preferred in a bunch of other vactrol circuits I'd like to build sometime, so they would come in handy anyway.
May I ask: Where are you getting yours?
C |
sneakthief
Coriolis
Posted: Wed Oct 11, 2006 12:04 pm Post subject:
Didn't know that one. A fairly limited selection so far though. And where are they located? US? EU?
Looks like they could get interesting though...
C |
sneakthief
Posted: Wed Oct 11, 2006 12:07 pm Post subject:
Bridechamber just opened shop in the US a couple of months ago. _________________ Sneak-Thief - raw electrofunk |
Posted: Mon Oct 16, 2006 4:02 am Post subject:
what about
http://www.banzaieffects.com
they're located in berlin, germany
or
http://www.musikding.de
they're situated in germany, too.
both are a good source for obsolete parts and particular das musikding is fast...
matthias |
sneakthief
Posted: Mon Oct 16, 2006 6:31 am Post subject:
if you want vtl5c3/2's, banzai and musikding cost more than twice as much _________________ Sneak-Thief - raw electrofunk |
