<on air> Howard Moscovitz Chez Mosc - No show tonight - sorry
 Forum index » Instruments and Equipment » Waldorf
Waldorf Function Problem,pleas help
Page 1 of 1 [5 Posts]
los vlados
PostPosted: Thu Oct 19, 2006 3:56 am    Post subject: Waldorf Function Problem,pleas help
Subject description: Waldorf Function Problem,pleas help
Hi i use the Waldorf Micro Q but i have a problem with the synth. after erasing the Flash memory. I download the new Waldorf Factory Sound Set_220.After reading the txt. document, i update the Operating Sistem whit the new 222 but after that i try to erase the memory before to upload the Sound Bank [ Inst 3 whit Global and Play ] the erasing was successfull but after that the synth stop to respond - can't load and operate the operating sistem , and can't receive midi message more.It's blocked. How can i sblock the synth.I try to Erase the memory again but the synth. don't respond .Some tips for Knob combinations ,Thank you.Only the Inst.3 - Global knob combination work for the Factory Test and in the Sistem Software is writen 1.47 light but the synth dont work.
Mohoyoho
PostPosted: Thu Oct 19, 2006 6:28 am    Post subject: Reply with quote  Mark this post and the followings unread
The Waldorf Users Forum is either down or gone, but here is a Yahoo users group that is still active:
http://launch.groups.yahoo.com/group/WaldorfQ/messages
Mark Mahoney
Kingsport, Tennessee
www.cdbaby.com/cd/markmahoney
Mohoyoho
PostPosted: Thu Oct 19, 2006 7:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's another resource:
http://faq.waldorfian.info/
Mark Mahoney
Mohoyoho
PostPosted: Thu Oct 19, 2006 7:04 am    Post subject: Reply with quote  Mark this post and the followings unread
I also found these instructions there:
Q: How to Update the Q/mQ O.S.
A: This is an important process since it can add all the new features of an OS update or, if done wrong, damage the Q. However, as long as you follow the steps detailed here or in the Q manual (downloadable from the Waldorf website) everything will work fine.
((And, if for some reason the power goes out during an OS upgrade, well you have only yourself to blame for not getting a conditioned backup power supply for your studio! Wink))
Q O.S.s come as standard MIDI files containing system exclusive data (SysEx) info which, when sent to the Q via MIDI just like a normal sequence, will be understood by the Q and burned into memory. The process is very similar to loading Q sounds.
There are two files which you will most likely need to update your Q with: the "boot" O.S. and the O.S. itself.
The Boot O.S. contains the data your Q uses to access the regular O.S. and is useful, for example, when an OS update attempt has failed. The Q (keyboard) and Q-rack both use the same O.S. and boot O.S., while the MicroQ has its own 2 O.S. files. Also, the Changelog.txt for the new O.S. will be available on Waldorf's site and will detail the features of the new O.S.
Insure that you get your Q O.S. update files from the Waldorf website. Its generaly a good idea to get the file(s) not long before you update to avoid the slim chance that various unrelated computer disk operations accidently corrupted the O.S. files, but this is very unlikely so its more of a precaution.
The Order is:
1) the O.S.
2) Boot O.S.
You do *not* need to restart the Q during the proceedure since after a succesful SysEx dump the Q the restart itslef to ennable the new O.S.
Mark Mahoney
los vlados
PostPosted: Thu Oct 19, 2006 8:16 am    Post subject: Waldorf Problem Reply with quote  Mark this post and the followings unread
Yes i have update the OS from the midi file,but the problem is when i try to erase and after the to update the sound's,but after erasing the memory of the Micro Q the synth stop to work, in this moment the synth can't receive midi and the OS update is imposible.Maybe whit some special knob comand receive midi,or update the sistem.When i turn it On he can load the OS and is blocked.Thank;s for the link.
