I can't believe IT STILL WORKS!!!
Page 1 of 1 [7 Posts]
richardc64
Audio files: 26
PostPosted: Thu Oct 19, 2006 2:48 pm    Post subject: I can't believe IT STILL WORKS!!! Reply with quote  Mark this post and the followings unread
This is what started me off. I didn't forget it, I just didn't know where it was. Re-discovered in a box this morning while looking for something else. A very early sequencer published in Popular Electronics, more than 30 years ago. Used RTL ICs: a hex inverter and 2 dual jk flipflops as a 4-bit ripple counter. Sixteen steps seemed too short to me so I extended it to 64 steps by adding another dual flipflop. I also added a dual NOR gate (that's right, only 2 gates to a package) and wired their outputs thru pots to the 2-transistor "vco", like 4 of the inverters. The remaining 2 inverters formed the clock. Instead of hard-wiring flipflip outputs to the inverters and gate, I brought all the Qs and /Qs out to 4-40 screws and and selected different combinations of bits with alligator clipleads. I'll try to find the schematic.
Radio Schlock didn't have .1" hole perfboard at the time so I had to drill new holes in the more common -- at the time -- perf with holes on .156" centers.
So today I put in 2 'D' cells and, damn! It started beepin' and boopin'! I suggest you keep the volume low if you play the wav sample. (The stuff to drive parents and neighbors nuts.)
 Filesize:  94.37 KB
 Viewed:  189 Time(s)
pe_sequence.wav
 Filename:  pe_sequence.wav
 Filesize:  62.08 KB
 Downloaded:  674 Time(s)
Audio files: 218
G2 patch files: 319
PostPosted: Thu Oct 19, 2006 2:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
It sounds just like it looks, beautiful, and a bit dusty Very Happy
Scott Stites
Audio files: 96
PostPosted: Thu Oct 19, 2006 7:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shocked
Wow - for me, it seems like a miracle anything electronic works, much less thirty years later....
PostPosted: Thu Oct 19, 2006 8:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
I love it!
Now that's an antique, family heirloom. Cool
zipzap
PostPosted: Fri Oct 20, 2006 3:45 am    Post subject: Reply with quote  Mark this post and the followings unread
hey uncle, you´ve changed...
http://www.myspace.com/lorolocoacousticpop
http://www.myspace.com/petrolvendor
music and transcribed jazz basslines
seraph
Editor
Editor
Audio files: 33
PostPosted: Fri Oct 20, 2006 5:31 am    Post subject: Reply with quote  Mark this post and the followings unread
right, which side is the real you Question
PostPosted: Fri Oct 20, 2006 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yep,
a change is as good as a holiday!
