Pot with parallel resistor
Page 1 of 1 [4 Posts]
PostPosted: Fri Oct 27, 2006 3:43 am    Post subject: Pot with parallel resistor Reply with quote  Mark this post and the followings unread
Here's a simple spreadsheet for anyone who's wondered what would be the effect of putting a parallel resistor across a variable resistor. I always assumed it would produce a non linear relationship, but it wasn't until I did this spreadsheet that I realised that the amount of non-linearity was dependant on the ratio of the two values.
It could be handy for when you want to use another value of pot.
I might improve it later to include graphs of other circuits, log pots etc.
Pot-Parallel-Resistor.xls
 Filename:  Pot-Parallel-Resistor.xls
 Filesize:  20.5 KB
 Downloaded:  162 Time(s)
fluxmonkey
PostPosted: Fri Oct 27, 2006 6:56 am    Post subject: Reply with quote  Mark this post and the followings unread
nice! also see:
http://sound.westhost.com/pots.htm
http://www.geofex.com/Article_Folders/potsecrets/potscret.htm
bbob
bugbrand
PostPosted: Fri Oct 27, 2006 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Both posts = mighty useful ---- THANKS!
http://www.bugbrand.co.uk
PostPosted: Fri Oct 27, 2006 2:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
and what about that:
http://www.mindspring.com/~clist/PotGraph.html
and that
http://www.elby-designs.com/documents/tailoringpotentionometers.pdf
a pot is a pot is a pot?
