 FAQFAQ   CalendarCalendar   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   LinksLinks GalleryGallery
Logical Operators in ChucK
Page 1 of 1 [2 Posts]
jbum
PostPosted: Fri Nov 03, 2006 3:20 pm    Post subject: Logical Operators in ChucK
Subject description: ...do not break off evaluation early, as in C...
Just a word of warning to seasoned 'C' programmers out there...
I was using a conditional statement like this one, to do a sanity check on an array index:
Code:
// DOES NOT WORK AS I EXPECTED
if (n < ary.cap() && ary[n] < 5)
  // do stuff...
Assuming that, like in C, the second part of the && expression would not be evaluated if the first part failed. This doesn't actually happen - the code generates an out-of-bounds message regardless. To fix it, I used this:
Code:
// WORKS
if (n < ary.cap())
  if (ary[n] < 5) {
     // do stuff...
<a href="http://www.krazydad.com/">krazydad.com</a>
<a href="http://www.coverpop.com/">coverpop.com</a>
Kassen
PostPosted: Fri Nov 03, 2006 9:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmmmm, I see no advantage here in ChucK's behaviour over C, sounds like a good feature to have.
while(!machine.crash() ) <<<"all is well">>>;
Music123.com - Customer Appreciation Sale Extended! - Save Up To $80 Off Your Order - Sale Ends Soon!
Copyright © 2003, 2004, 2005, 2006 and 2007 by electro-music.com
