how do you maipulate an array with rand2()?
Page 1 of 1 [7 Posts]
laserbeak
PostPosted: Mon Nov 13, 2006 6:40 pm    Post subject: how do you maipulate an array with rand2()?
Subject description: trying to access an array with rand2()?
hi
i'm trying to access an array with rand2() but i get syntax errors:
Code:
while( true )
   //1 bar at 180bpm cut into 8ths
   float push[ 0, 166.625, 333.25, 499.875, 666.5, 833.125, 999.75, 1166.375 ]
    push[Math.rand2(0,7)] => buf.pos;
    1333::ms => now;
laserbeak
PostPosted: Mon Nov 13, 2006 8:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
i noticed my syntax errors in comparison to otf_06.ck on page 49 in the manual and re-wrote it.
Code:
// time loop
while( true )
   [ 0, 166.625, 333.25, 499.875, 666.5, 833.125, 999.75, 1166.375 ]@=> float push[];
    1333::ms => now;
but i still get this error: [SndBufTest1.ck]:line(19): array init [...] contains incompatible types...
laserbeak
PostPosted: Mon Nov 13, 2006 8:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok so i realise the the .pos command is int
so then i rounded all my values to the highest whole value and made the array an int. i dont get any errors anymore but Chuck acts as if the array isnt even there.
Code:
while( true )
   [ 0, 167, 333, 500, 667, 833, 1000, 1166 ] @=> int push[];
    1333::ms => now;
majutsu
PostPosted: Mon Nov 13, 2006 9:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
for starters
try Std.rand2()
it's std namespace, not math, i believe.
furthermore, Std.rand() generates a random number between 0 and 1. rand2(min, max) generates a random number between min and max, you have no values, so you always generate zero i think.
good luck.
laserbeak
PostPosted: Mon Nov 13, 2006 9:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok
did it.
no errors but no desired effect either
majutsu
PostPosted: Mon Nov 13, 2006 9:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
please read rest of post you were typing while i was on first paragraph Very Happy
anxious to get started i see. that's good!
All phenomena are atoms in association and dissociation.
laserbeak
PostPosted: Mon Nov 13, 2006 9:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
hehe yes i'm quite anxious Smile
but i do have values(i think)
push[Std.rand2(0,7)] => buf.pos;
Buy N Save
