laserbeak
Joined: Nov 12, 2006 Posts: 15 Location: East Coast U.S.Ass
Posted: Sun Nov 12, 2006 10:18 pm Post subject:
SndBuf: syntax for reading the number of samples Subject description: part 1 in a newb's series of SndBuf questions |
hi,
i'm new to chuck and find it very interesting. the fact that it works in real-time makes it very inspiring to experiment with code(i've been trying to learn c++ for 7 years and am still a newb for this reason)
anyway, to my question:
i dont know the syntax to get the samples from a sound in SndBuf.
let's say, for example, that i wanted to use C:\samples\drumloop
how would i type that correctly using the buf.samples command to find the number of samples?
-edit-
and are those number of samples in ms?
i've been trying a few things and i got this i think it works
| Code: |
// the patch
SndBuf buf => dac;
// load the file
"E:\samples\AmenMRZ2-180bpm.wav" => buf.read;
buf.samples() => int mysamps;
<<<mysamps>>>;
// time loop
while( true )
0 => buf.pos;
1325::ms => now;
wich gives me this output
| Code: |
[chuck](VM): replacing shred 3 (unnamed1) with 3 (unnamed1)...
58800 :(int)
now the value 58800 seems to be the samples but this is a 1bar loop at 180bpm, and although i havent taken the time to figure out how to calculate the exact time of a 4 beat bar at 180Bpm, i know that 1325 is VERY close. so why does 58800 get ouptut? |
Kassen
Joined: Jul 06, 2004 Posts: 6249 Location: The Hague, NL
Posted: Mon Nov 13, 2006 4:54 am Post subject:
Re: SndBuf: syntax for reading the number of samples Subject description: part 1 in a newb's series of SndBuf questions |
| laserbeak wrote: | how would i type that correctly using the buf.samples command to find the number of samples?
Hi, Laserbeak!
(wasn't that one of the Decepticons that changed into a casette tape?)
You get the number of samples exactly like in your example;
buf.samples() => int NumberOfSamples;
So; to play a file in reverse;
//create a sndbuf
SndBuf buf => dac;
//load some sample
"boom.wav" => buf.read;
//get the number of samples and use it to set the buffer's position to the end
buf.samples() => buf.pos
//reverse the playback direction
-1 => buf.rate;
| Quote: | | and are those number of samples in ms? |
No, those are in "samples" so the number you get is the exact number of values that defines your wave file.
This means that in a cd quality audio file a sample that lasts one second will have 44100 samples.
It also means that if you would have some realy lo-fi wave sampled at 1000Hz the number of samples would also be the number of ms.
180BPM means 1.5 beats every second so (asuming cd quality audio) that means a "beat" lasts (44100 / 1.5) = 29400 samples.
29400 * 2 = 58800 samples so you count your beats twice as fast as the bpm would indicate, it also means you have a wave file that's cut very precisely! (often they have a few samples of rounding error.)
Does that help? _________________ while(!machine.crash() ) <<<"all is well">>>; |
laserbeak
Posted: Mon Nov 13, 2006 7:16 am Post subject:
| Kassen wrote: |
Hi, Laserbeak!
Yes
| Kassen wrote: |
Oh yeah!! Forgot about that!
| Kassen wrote: |
So does that mean that 58800 samples is 3000ms? I think that i would probably be easier to create a function or class that would convert samples to milliseconds for me to read from although math is math in any form.
| Kassen wrote: |
Hehe, yes i use FLStudio to cut my loops. Havent figured out what im gonna use in Linux yet though. Maybe EnergyXT2 when that gets released. |
kijjaz
Joined: Sep 20, 2004 Posts: 452 Location: bangkok, thailand
Posted: Mon Nov 13, 2006 12:09 pm Post subject:
Laserbeak: It's nice seeing you here in chuck forum, my csound brother.. haha
ok anyway, let's play more with what you're playing.
now let's talk more about 'BPM'
we'll need a few mathematics.
ok.. let us have float bpm as the tempo of the music.
it's bpm beats per minute
= bpm beats per 60 seconds
= (bpm / 60) beats per second
so for one second, we've got (bpm/60) beats passed.
but what we're gonna use is the 'second passed.
so we need to calculate how long each beat takes.
1 second = bpm/60 beats
60 second = bpm beats
(60 / bpm) second = 1 beat
so actually, 1 beat equals 60/bpm
my idea is this:
// first, initiate BPM
180.0 => float BPM;
// calculate beat
60.0 / BPM :: second => dur beat;
// you can even calculate bar by define how many beats per bar
beat * 4 => dur bar;
with this, you can use beat or bar as the duration depending on the init value of BPM.
laserbeak: So does that mean that 58800 samples is 3000ms? I think that i would probably be easier to create a function or class that would convert samples to milliseconds for me to read from although math is math in any form.
kijjaz: you might have to check out Kassen's idea.
first, you'll need to find out the samplerate of the wavefile you're playing.
let's say we have SndBuf buf;
the sample rate of buf would be 'how many samples per second'
so that would be buf.samples() / buf.length() - - - (1)
then check out the current real-time sample rate
it's second / samp - - - (2)
to be able to play the wave with original speed,
we'll need to find the ratio between the sample's rate and the virtual machine's rate..
the ratio would be (1) / (2)
ok.. let's set the buf's read rate.
(buf.samples() / buf.length()) / (second / samp) => buf.rate;
and now you can play the file at the original rate without having to care about virtual machine's different sample rate.
!! ... this is my idea, still haven't been tested well
is my calculations correct? |
kijjaz
Posted: Mon Nov 13, 2006 12:35 pm Post subject:
i was wrong!
in chuck manual, SndBuf's length() fetches length in seconds
but actually ..
SndBuf buf => dac;
buf.read("special:glot_ahh");
<<< buf.length() >>>;
prints out: 992.000000 :(dur)
so this is one thing that needs to be changed in the manual.
now i can check out sample rate by..
<<< buf.samples() / (buf.length() / second) >>>;
prints out: 44100.000000 :(float) (works okay..) |
laserbeak
Posted: Mon Nov 13, 2006 12:51 pm Post subject:
| where'd you find the .length() function???? |
laserbeak
Posted: Mon Nov 13, 2006 1:06 pm Post subject:
so buf.length() / ms => float length; wil return the value in milliseconds. cool!!
thanks guys!! |
spencer
Joined: Aug 16, 2006 Posts: 52 Location: northern california
laserbeak
Posted: Tue Nov 14, 2006 3:45 pm Post subject:
ok i found it on the webpage already, thanks. didnt think it was in the manual. but i'll look again |
majutsu
Joined: Jun 18, 2006 Posts: 142 Location: louisiana usa
Posted: Tue Nov 14, 2006 8:36 pm Post subject:
actually, even more interestingly, length() seems to return something very close to the number of samples despite the manual saying otherwise. but samples() returns a number of samples DIFFERENT than length(), in my experience a few thousand different. And neither matches the samples length as they were generated in me by soundforge or whatever. this makes beat slicing in chuck problem-ridden at this point. I either use single shot samples or slice the sample on the beat in chuck and play the slices forward or backward at different speeds. More beat-slicing accuracy than this in chuck is not had at this time (1.2.7b) _________________ All phenomena are atoms in association and dissociation. |
laserbeak
Posted: Tue Nov 14, 2006 9:08 pm Post subject:
thats disapointing and you might be right if a bar at 180bpm is 1.5ms and not 1.3
i guess i could try slicing my loops and sequencing them that way |
kijjaz
Posted: Wed Nov 15, 2006 7:33 am Post subject:
hmm.. is that so?
i didn't test .length() in many cases..
but i guess since there might be a problem with length,
we should stick to .samp() for now..
eh .. and is there any way to retrieve SampleRate without using .length() ? |
Kassen
Posted: Tue Nov 21, 2006 11:42 am Post subject:
| majutsu wrote: | | And neither matches the samples length as they were generated in me by soundforge or whatever. |
Hmmmm, that sounds like a issue or bug somewhere?
What you can always do is take the number of samples as given by chuck and take the number of samples in the time period you want the loop to span. You then devide those and send the result to SndBuf.rate to sync it turntable style. Quick&dirty and it might give tuning issues for melodic material but it's cheaper then a copy of Ableton Live too . _________________ while(!machine.crash() ) <<<"all is well">>>; |
