hyperstationjr
Joined: Jun 12, 2005 Posts: 111 Location: New Jersey/New York
G2 patch files: 24
Posted: Wed Nov 22, 2006 10:09 pm Post subject:
G2 overall patchload? |
Am I missing something? I thought the G2 had 4 (or 8 ) independent DSP chips...
I'm trying to ensemble a live perf. patch..
Slot A: 50% cy., 98% mem. for both VA and FX
Slot B: 89% cy., 91% mem. for VA, FX is empty...
Slot C: 90% cy., 99% mem. for FX, VA is empty...
Slot D: 31% cy., 74% mem. for FX, VA is empty...
Slots C and D don't run...
Slot A is all sequencing, with switches and random triggers...
Slot B is a bank of 6 Fm based percussion synths...
Slot C is a delay-based effect with lots of LFO's...
Slot D is a reverser with delay and an LFO...
What gives? Is there some sort of general limit aside from the max. DSP per patch? If so this is going to KILL me... _________________ Studio:
Blokas MidiHub, Clavia Nord Modular G2 Engine, Elektron Analog Four Mk2, Elektron Digitone, Elektron Machinedrum UW+ Mk2, Elektron Octatrack Mk2
For Sale/Trade:
Alesis Microverb 4, Make Noise 0-Coast, Monome Norns Fates clone, Panasonic RQ-705 Reel-to-reel, Roland Alpha Juno1, Yamaha TG55 |
Posted: Thu Nov 23, 2006 12:17 am Post subject:
How many voices are you requesting for each slot? Each voice request makes a copy of the VA area into the DSP pool. The FX is copied only once, no matter how many voices are requested. So it looks like A, C & D would request 1 voice, but your B slot may be killing you. |
hyperstationjr
G2 patch files: 24
Posted: Thu Nov 23, 2006 12:36 am Post subject:
1 per (mono), since most of them are sequencers or effects which don't depend on a voice. Even the Drum Synths are mono... _________________ Studio:
For Sale/Trade:
Fozzie
Joined: Jun 04, 2004 Posts: 875 Location: Near Wageningen, the Netherlands
G2 patch files: 49
Posted: Thu Nov 23, 2006 1:37 am Post subject:
I'm surprised your C-slot won't work, as I would guess this to happen:
Slot A: 2 dsp's since VA and FX are filled (if both take >50% of either cy or fx, 2 dsp's are used)
Slot B: 1 dsp (only FX is filled)
That would leave 1 dsp for Slot C in my mind, but apparently is doesn't. It is not surprising that Slot D doesn't work, that would require a fifth dsp.
Delete slot D, and see if C starts working. Or put everything in va + FX of slot A & B; that way you could never take more than 4 dsp's. If VA is set to mono, there is no difference between VA or FX. If it still doesn't work when everything is cramped into slot A & B VA+FX, chances are you have crossed the limit of the amount of modules per slot, but I believe that only happens when you have >100 modules. _________________ Spinning at ~0.0000115740740741 Hz |
sheridan
Joined: Jun 05, 2005 Posts: 473 Location: London, England
Audio files: 27
Posted: Thu Nov 23, 2006 6:19 am Post subject:
Here are a few DSP saving ideas...
If you use more than one voice, try keeping patch load under 50%. You can do this by moving any modules that don't need polyphony to the FX area, ie. almost all modules except oscillators, LFOs, other modules that have mono/poly buttons set to poly, etc. This way, fewer modules will be effected enabling higher voice counts. The important DSP figures to stay under are 25%, 33%, or 50%.
Also, try economising your modules, ie. if you only need an oscillator to produce one waveform, use the Osc C or D modules which 'cost' less DSP. The same goes for LFOs, Envelopes, Filters and many other modules.
I hope that helps. _________________ Sheridan
Hear music and Nord Modular G2 patches and find out music production tips at
http://www.nitetimeproductions.co.uk |
dasz
Joined: Oct 16, 2004 Posts: 1644 Location: victoria, canada
Audio files: 29
G2 patch files: 56
Posted: Thu Nov 23, 2006 8:43 am Post subject:
And your memory % look okay in slot c and d? or is any of them red?
/Dasz |
hyperstationjr
G2 patch files: 24
Posted: Thu Nov 23, 2006 11:56 am Post subject:
Slot C and D are in the red, but are under their max DSP percentage, which is what's confusing me.. I'm not going over the limit on ANY of Slots, but for whatever reason, they crap out...
As for DSP-saving, done. Funny thing is al the "old" G1 tricks, like using an LFO as an oscillator, don't really work, and even a basic LFO (aside from LFO C) are as much or more than a basic FM Osc. (which is the only osc I'm using in the .perf).
I'm also using MULTI Filters w/ mixers as opposed to a NORD filter... I am using MUTLI Envelops as opposed to ADSR's but that's not a world of difference really...
But again, in some cases, I'm only using one aspect of the DSP (VA or FX) and while I am getting close to the ceiling of each Slot, I don't understand why I can't use say 60% on every slot...
Is there a max per module? I don't see how that would be possible... _________________ Studio:
For Sale/Trade:
ian-s
Joined: Apr 01, 2004 Posts: 2669 Location: Auckland, New Zealand
Audio files: 42
G2 patch files: 626
Posted: Thu Nov 23, 2006 12:00 pm Post subject:
can you post the prf? |
hyperstationjr
G2 patch files: 24
Posted: Thu Nov 23, 2006 12:08 pm Post subject:
To be honest.. I do feel a little funny about it, but if it will help get the thing off the ground, then I suppose so.
Description: |
Download |
Filename: |
-LIVE7 (web).prf2 |
Filesize: |
28.41 KB |
Downloaded: |
1133 Time(s) |
For Sale/Trade:
sheridan
Audio files: 27
Posted: Thu Nov 23, 2006 12:13 pm Post subject:
Four slots at 60% is the same as four slots using between 51% and 100% and will use 4 DSPs.
I recommend expanding... the extra 4 DSPs come in handy! _________________ Sheridan
Audio files: 278
Posted: Thu Nov 23, 2006 2:36 pm Post subject:
This is a bit strange.
I see some slots are set to legato and I never tried that so maybe that's part of the problem ?
Otherwise it must be a miscalculation of resource usage by the editor. The percentages should make it possible to have slots A, B and C running or ABD or actually all combinations of three patches, but not ABCD (on an unexpanded modular).
The limiting factor here is memory, all patch areas are above 50% for that and so you can only have have four areas (for four dsp's). As slot B wants two areas something has to give in.
(an area's memory must be allocated on the same dsp as it's cycles). _________________ Jan
dasz
Audio files: 29
G2 patch files: 56
Posted: Thu Nov 23, 2006 6:10 pm Post subject:
(an area's memory must be allocated on the same dsp as it's cycles). |
that's what I was thinking
/Dasz |
Unfed
Joined: May 11, 2004 Posts: 200 Location: Rochester, NY
G2 patch files: 11
Posted: Thu Nov 30, 2006 3:15 am Post subject:
any idea as to why i'm getting a checksum error when trying to open this file? never had that happen before. i've tried downloading it twice, even renaming it. is everyone else able to load this ok? _________________ SoundCloud |
Audio files: 278
Posted: Thu Nov 30, 2006 2:35 pm Post subject:
Unfed wrote: | is everyone else able to load this ok? |
For me it's ok. _________________ Jan
dasz
Audio files: 29
G2 patch files: 56
Posted: Thu Nov 30, 2006 6:38 pm Post subject:
worked fine here too.
/Dasz |
Unfed
G2 patch files: 11
Posted: Thu Nov 30, 2006 7:42 pm Post subject:
"can't load file. checksum error. could not load file."
this is what i'm getting, any ideas what might cause this? i can't get it to open on either of the computers here. never had this problem before, other patches and performances open as usual. _________________ SoundCloud |
hyperstationjr
G2 patch files: 24
Posted: Fri Dec 01, 2006 9:50 am Post subject:
I could e-mail the file to you if you'd like... Here's a new version anyways... waaaaay slimmed down.
I'm doing a lot more in LIVE, including effects, samplers and mixing. I'm a little uneasy about that, and may look into trying to throw Mac OSX onto my older Sony laptop in hopes of getting better results... we'll see...
Description: |
Download |
Filename: |
-LIVE12 (web).prf2 |
Filesize: |
32.79 KB |
Downloaded: |
1082 Time(s) |
For Sale/Trade:
Audio files: 278
Posted: Fri Dec 01, 2006 2:17 pm Post subject:
Unfed wrote: | "any ideas what might cause this? |
I don't really know, except that there indeed is a checksum at the end of a patch, so probably for some reason the download was not successfull. _________________ Jan
