 Forum index » Instruments and Equipment » MAX/MSP - Pd
so can i pull off this linux thing?
Page 1 of 1 [6 Posts]
skelly
PostPosted: Wed Nov 22, 2006 2:44 pm    Post subject: so can i pull off this linux thing?
Subject description: pd as a possible substitute for max/msp
hi all, id like to substitute max/msp for pd, but have been unable to open my .pat files in pd at all. has anyone else done this switch? is there a converter of some-sort? im sure there is something.
thank you
-spencer
PostPosted: Wed Nov 22, 2006 3:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome
to electro-music.com.
I don't know anyone whose switched from MAX/MSP to Pd, but I'll bet you can find someone here: http://puredata.info/.
I know there are libraries & such for using common externals as extensions to both MAX/MSP and Pd. But I don't know about sharing patches. Would be worthwhile to find it, however.
I'll see what I can dig up, but please post any findings back here!
franzrosati
PostPosted: Sun Nov 26, 2006 8:45 am    Post subject: Reply with quote  Mark this post and the followings unread
hi, i've started with max and now i'm slowly migrating to PD...anyway, you can use a .pat in pd but you must have the cyclone library that has some max-objects ported to Pd.
So far, Pd doesn't have all the max externals so you could have some bogus.
As a first step, i suggest you to install the pd-extended version Smile
bye bye
www.franzrosati.com
flowersniffer7
PostPosted: Tue Nov 28, 2006 12:23 am    Post subject: Reply with quote  Mark this post and the followings unread
bye bye
Yeah, I went from PD to Max and my PD files have for the most part not fully worked in Max due to the issue pointed out above... Seems to work both ways... However there are some pretty massive archives of Max and PD externals which can be imported to fix some, but obviously not all discrepancies...
franzrosati
PostPosted: Mon Dec 04, 2006 5:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
i think one of the best ways to try Pd full working with loads of compiled libs is to install pure:dyne linux distribution Smile
www.franzrosati.com
skelly
PostPosted: Wed Dec 06, 2006 8:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
pd-extended!
pure:dyne!
thank you!
Niio1
