<on air> Antimon Antimon Waves
ARP AXXE. Can it be "patched out"?
Page 1 of 1 [11 Posts]
Wild Zebra
PostPosted: Thu Dec 07, 2006 12:16 pm    Post subject: ARP AXXE. Can it be "patched out"?
Subject description: Friend has a beat up axxe and wanted to know if I could mod it
Just like the topic says. Someone gave my buddy a beat up Axxe and he wanted to know if there was a way to patch it out. I reckon it could, but I wouldn't know were to start. I guess with a schem and a little knudge in the right direction.
"your stripes are killer bro"
PostPosted: Thu Dec 07, 2006 12:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
I reckon it could be done, but it makes more sense to restore it.
ickystay
PostPosted: Thu Dec 07, 2006 1:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's a patched out Axxe:
http://www.cykong.com/Synths/ARP%20Axxe%20AS%20Modular/ArpAxxeModular(AS).htm
I was hoping this guy would show how his was done (and save me the trouble with my Axxe pcb), but I guess not.
There is a nice service manual on the web. You'll have to google it up. My folder is called "Axxe2300servicemanual" so it must have been a zip file.
edit- here> http://www.synthdiy.com/show/showproduct.asp?id=914
PostPosted: Thu Dec 07, 2006 2:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
err, no. A dead link.
Perhaps we put the server into shock? Shocked
ACHTUNG!
G2 patch files: 625
PostPosted: Thu Dec 07, 2006 2:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Patching out would be good for integrating with other modular gear. As a stand alone synth though, the Axxe has almost every possible routing covered with a panel control. It can do this because it has so few modules.
PostPosted: Thu Dec 07, 2006 2:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
The Axxe and The Oddysey (and 'The little brother'- remember that one?? Wink ) were the business. They were the instruments of my dreams when I was a kid. It wasn't so much the sound, but the routing possibilities.
However, modular synthesis today is an expensive business, and modding a monofonik synth is (was) a cheap way of getting some good vanilla modules for a cheap(ish) price.
ACHTUNG!
ickystay
PostPosted: Thu Dec 07, 2006 6:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm. The last bit of the url stops being clickable.
Try here and scroll down to his Axxe:
http://www.cykong.com/Synths/synths.htm
Wild Zebra
PostPosted: Fri Dec 08, 2006 7:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Well thanks for the words and links so far. I'll have to ask my friend what he wants to get out of it. He's got a 2600 so maybe he wants a little expander? Some things aren't working, but maybe it just needs and old fashioned cleaning.
Wild Zebra
PostPosted: Fri Dec 08, 2006 9:06 am    Post subject: Reply with quote  Mark this post and the followings unread
I finally got to that site. I have a Korg 700. Hmmmmm I see alittle modding in my future. I'm sure this is the type of thing my friend has in mind. Too bad there isn't a tutorial on the AXXE too.
piedwagtail
PostPosted: Thu Dec 14, 2006 4:29 am    Post subject: Reply with quote  Mark this post and the followings unread
I patched out a Solus,wasn't too difficult.
I found the service manual later.
But basically just tapped out the test points.
Most of the Arps seem to have consistent test points marked TP1...etc. on the boards and they are relatively easy to sort out.Saw,Square,Lfo,filter,env etc.
The oscillator is half an Odyssey,so just trace from that service manual.The traces will look the same.Filter same.
Of course someone might bust in to say,that they should all be buffered with opamps but i found in practice it does alright without.
I personally don't think an Axxe has much collector value,just dive in....it is a good learning experience.
I found the 70s Arp PCBs to be a bugger to desolder compared to say 70s SEMs,the traces often flake,so if you upgrade the filter resistors,a good mod,bypass rather than replace.
Dealing with just the test point solder islands will not be so daunting.
Robert
Wild Zebra
PostPosted: Thu Dec 14, 2006 7:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks !
