zipzap
Posted: Thu Dec 21, 2006 2:23 am Post subject:
Pausing metronom |
Hi people
Not very synth related, but part of the sequencing pattern generating buisness. So i´m sure someone has a hint for me.
I want to build a special metronom for practicing music.
It has the following function:
Once started you get 16 clicks (4 bars).
Mode one: start over (continuos, normal metronome)
Mode two: after 16 clicks mute for 4 clicks
mode three: mute for 8 clicks
mode four: mute for 16 clicks.
If you check this out with a drumbox you realise that its quite hard, but once you´re able to keep the tempo for 4 bars with no click, and still be in time when the metronome comes back in, you´ve got it.
How to build such a device? I could imagine chaining some 4017s and some and gates doing the job. But i guess there´s a better way.
Any idea? No mcs please, just plain cmos. Is there a good chip for the job?
cheers, jens _________________ http://www.myspace.com/lorolocoacousticpop
music and transcribed jazz basslines |
Scott Stites
Joined: Dec 23, 2005 Posts: 4119 Location: Mount Hope, KS USA
Audio files: 96
Posted: Thu Dec 21, 2006 10:58 pm Post subject:
Hey ZipZap,
Without actually having tried it, but in the midst of working on a totally ridiculous new digital design, so all of this stuff is freshly swirling in my swollen noggin, I'll venture this:
A CD4516, A CD4013 Flipflop, and a well placed AND gate ought to get you there. Mebbe a CD40106 Schmitt trigger. Of course, a clock would be needed. Connect the clock to one input of the AND gate, and:
Tie the other input of the AND gate high.
On one section of the CD4013, connect /Q to the data input. Connect the carry out of the CD4516 to the clock input of this section. Connect /Q to the AND gate. Connect the /4 output of the CD4516 to the reset input of the flip flop. Differentiate Q and connect it to the reset input of the 4516 so that you get a high pulse when Flip Flop Q transistions from high to low (this is where the Schmitt trigger would make a nice, very thin pulse to do it with).
Counter counts to 16, CO flips the CD4013 high, driving /Q low, which stops the clock from appearing on the output of the AND gate. Counts four times, the flip flop gets reset, /Q goes goes high, Q goes low, which creates a pulse to allow the counter to reset and count 16 more times before the process repeats.
16 counts flip....4 counts flop....16 counts flip....four counts flop.
Same as above, but connect the divide by 8 output to the reset input of the flip flop.
16 counts flip...8 counts flop....16 counts flip...8 counts flop......
Ground the reset input of the flip flop. 16 counts Flip...16 counts flop....flip....flop.
Well, it might be worth a try(?).
Cheerios,
Scott |
