gabbe
Posted: Wed Nov 22, 2006 11:04 am Post subject:
Problems with Nord Lead 2 |
When I'm splitting the synth it's just coming sound out of the one half of it. What should i do? |
Wout Blommers
Audio files: 123
G2 patch files: 12
Joined: Apr 03, 2004 Posts: 24081 Location: The Netherlands, Enschede
Audio files: 278
Posted: Fri Nov 24, 2006 1:49 pm Post subject:
Good idea Wout :D
I moved the post. _________________ Jan
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sat Nov 25, 2006 6:49 am Post subject:
Yes, here's the right place
First of all, the Manual is always download able from Clavia's site in pdf format. It's on page 14.
Activate the split by pressing the button.
Activate at least two Slots, best is Slot A and Slot C.
Slot A will sound in the lower half, Slot C in the upper half.
After this, select the sounds you want to use.
By [Shift+Split] you can change the splitting point of your keyboard.
Be sure Slot C+D are set to the same output. [Manual page 59]
Mostly Slot A+B are set in stereo [ab3], so when you select Slot C+D it has to be [cd-], which means the same as Slot A+B.
If your synth is a NordLead(Rack) or NordLead(Rack)2, you'll need a PCMIA card to save the settings as a performance; no problem to do this on a NordLead(Rack)2X.
Wheel and PitchStick are global, so if you use for your right hand a lead sound and in the left a beautiful bass, the later will change in pitch too!
Hope all is clear...
Wout Last edited by Wout Blommers on Sat Nov 25, 2006 2:26 pm; edited 1 time in total |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sat Nov 25, 2006 2:23 pm Post subject:
Wout Blommers wrote: | By [Shift+Split] you can change the splitting point of your keyboard. |
Forgot to write: when playing any key, while holding [Shift+Split], that key will be the lowest key of the upper part.
Wout |
gabbe
Posted: Sat Dec 23, 2006 4:48 pm Post subject:
Its bin a while since I posted anything in this thread, but it comes just sound from the lowest part of NL2, not te highest... Any suggestions? |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sat Dec 23, 2006 5:27 pm Post subject:
Do you have two Slots activated?
Slot A & B are used for the lower part, Slot C & D for the upper part.
Wout |
gabbe
Posted: Sat Dec 23, 2006 5:29 pm Post subject:
Yes, i have. But it does not come any sound if I have selected C, even when the keyboard is not split. |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sat Dec 23, 2006 5:32 pm Post subject:
gabbe wrote: | Yes, i have. But it does not come any sound if I have selected C, even when the keyboard is not split. |
How about the output routing of Slot C?
If it's set to output 3 and you're only using output 1 & 2...
Wout |
gabbe
Posted: Sat Dec 23, 2006 5:59 pm Post subject:
Ah, that's the problem, it works perfectly now Thanks for the help! |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sun Dec 24, 2006 4:59 am Post subject:
Hey, I just noticed you changed your last mail!
I was writing a long story and at the same moment you solved your own problem
Just for the records, here is my, for the moment redundant, answer:
gabbe wrote: | Ah, that's probably the problem, how do i change that? |
Well, there is of course the Manual, downloadable at Clavia's site:
http://www.clavia.se/products/manuals.htm#nl2
Take a look at page 59 - Out Mode.
BTW it continues on page 60
Further more, if you have a NordLead2(X), it's also written in the text on the panel itself, the second item.
It reads:
OUT MODE
Slot C and D
-.cd Slot C and D routed same as A and B
Anyway, press [Shift+SlotB] > Out Mode.
press [SlotB] (without the Shift) again and you'll find the settings of Slot C & D.
When it reads [-.cd] it will copy the settings of Slot A & B.
If there is another setting, e.g. [4.cd], change the first value to [-.cd] using the the up & down buttons beneath the display.
Of course the Slot A & B settings have to be [1.ab]
Let me know if it works...
The NordLead has a very open and easy to understand interface, apart of these kind of [Shift] functions, which work using menu's. At the other hand, once set the synth will mostly stay this way, until it will find a new owner.
Wout |
gabbe
Posted: Sun Dec 24, 2006 7:11 am Post subject:
Yeah, i kinda figure it out myself, but thanks for the help anyway! Btw, do you know about any natural piano sounds out there? |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sun Dec 24, 2006 1:53 pm Post subject:
That's what the Electro and Stage are for...
If you want to do it on a Lead, you have to think about performances.
Let us know about some results, because with a little help it can be done.
Wout |
Erv
Posted: Sun Jun 26, 2016 7:35 pm Post subject:
KBD Split not Work, only as trig note in NL2 ¿ whi ? |
hi Boys, i revive this topic for solve a following problem:
¿ my Nord Lead 2 requires of some trick for activated KBD Split ?
when buy it 4 months ago (I am the third owner), i was in the same situation than now, which did not work the KBD Split, at that time, had found on the internet, a procedure to enable the KBD Split, and I remember than had to press a combination of buttons.. or configure something
It was different from that specified in the manual
and had worked
but now I press the KBD Split and only trigger a Do3 note as if it were a Nord Lead 2 Rack |
