free PDF tools for Windows
Post new topic   Reply to topic Moderators: Blue Hell
Page 1 of 1 [9 Posts]
Audio files: 169
G2 patch files: 319
PostPosted: Sat Jul 22, 2006 9:58 am    Post subject: free PDF tools for Windows Reply with quote  Mark this post and the followings unread
In this thread the subject came up as how to combine multiple PDF pages into a single document without using the Adobe tools.
As it happens GhostScript can do that (and more) for you. The web site pointed to has some more usefull tools you might want to look into, like a port redirector that has been of good use to me in the past.
I wrote a little helper aplication for GhostScript to assist in combining pages. My normal use is to make PostScript files first and then to combine those into a single PDF document. The help file that comes along reflects that use, but it doesn't really matter if the source material is PostScript or PDF (PDF being a PostScript derivative).
The ini file that comes along is the one that I last used, you might want to change those.
Stoker BTW is dutch for distiller [ One that makes alcoholic liquors by the process of distillation.].
stoker.zip
Stoker, a GhostScript wrapper tool for PDF creation
 Filename:  stoker.zip
 Filesize:  325.97 KB
 Downloaded:  204 Time(s)
brinxmat
PostPosted: Mon Jul 24, 2006 5:30 am    Post subject: Reply with quote  Mark this post and the followings unread
gs -q -dNOPAUSE -dBATCH -sDEVICE=pdfwrite -sOutputFile=Output.pdf 1.pdf 2.pdf 3.pdf
I should definitely write a wrapper for that one.
-- Say "&Eth;onne hit wæs hrenig weðer"
Audio files: 169
G2 patch files: 319
PostPosted: Mon Jul 24, 2006 5:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes that and then a few more for paper sizes and dpi's. Too much for me to remember anyway :)
Audio files: 130
PostPosted: Mon Jul 24, 2006 11:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, Jan.
Doesn't gs require the input files to be postscript?
Audio files: 169
G2 patch files: 319
PostPosted: Mon Jul 24, 2006 12:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
No it handles pdf as well, as pdf is very much like PS.
Audio files: 130
PostPosted: Mon Jul 24, 2006 12:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Then how to convert png images to PDF? I scaned everything to png. Then I read the pngs into OpenOffice. OpenOffice combines all of the images into one document writes out PDF with one click. That is the solution I used for this job. Thanks for the gs info and the program.
Audio files: 169
G2 patch files: 319
PostPosted: Mon Jul 24, 2006 12:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
By printing them to a PS printer that redirects to a file giving a PS file as the result. Once set up its not too troublesome.
I had seen the creater to be open office in the pdf doc you posted. I'm not too fond of open office myself - well the older versions that is, but didn't look at it for a while.
But please be happy the way you like it Very Happy
brinxmat
PostPosted: Tue Jul 25, 2006 4:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes that and then a few more for paper sizes and dpi's. Too much for me to remember anyway Smile
-sPAPERSIZE=a4
-dDEVICEXRESOLUTION=300 -dDEVICEYRESOLUTION=300
(not that either of these will reliably affect anything -- papersize might, but I don't know if device resolution affects anything unless you specify device characteristics. I find that it is best to feed GS with files that have the right paper size and resolution before batch converting. I am probably overly cautious. Also document paper size in PDF is only nominally important: you can have varied paper sizes, including different rotations.)
regarding png: I direct you to http://png2pdf.sourceforge.net/ this kind of thing takes a lot of the work out of this kind of job. There are a lot of these kind of converters included in the std gs distro.
JuergenPB
PostPosted: Tue Nov 06, 2007 11:43 am    Post subject: Reply with quote  Mark this post and the followings unread
A nice tool: http://www.pdfill.com/pdf_tools_free.html
PDF-Reader: http://www.foxitsoftware.com/pdf/rd_intro.php
Overview
Foxit Reader is a free PDF document viewer and printer, with incredible small size (only 2.1 M download size), breezing-fast launch speed and amazingly rich feature set. Foxit Reader supports Windows 98/Me/2000/XP/2003/Vista. Its core function is compatible with PDF Standard 1.7.
