8/15 logic signals over one bus using DA/AD
Page 1 of 1 [2 Posts]
selvmarcus
G2 patch files: 39
PostPosted: Mon Mar 27, 2006 11:30 pm    Post subject: 8/15 logic signals over one bus using DA/AD Reply with quote  Mark this post and the followings unread
You can see the voice allocation at work.
The first patch is routing gate signal of a voice as a specific bit
from VA to FX via bus1 by coding as individual bits d0-d7 in signal.
The keyboard gate is routed to DA via a multiplexer addressed by
the voices number aquired from status module.
In FX, signals from bus1 is AD-decoded. This way all gates from 8
voices are displayed as leds simultaneously.
The second patch is doing the same with 15 voices, in VA
by shifting DA-coded signal (from first 7 voices) 7 bits to the right by
a mixer with minimum gain setting and summing with the other 8 bit from the other 8 voices.
The bit D7 is not usable at lower portion for some reason. Will check again.
In FX, top 8 bits are AD-decoded, DA-recoded and subtracted from
signal to get rid of high bits, then 7 times level amplified by x2
to shift lower 7 bits back in position.
All the best,
/Marcus
voice_alloc8_SM.pch2
Displays gates of 8 allocated voice in FX-area by DA/AD coding on one bus
 Filename:  voice_alloc8_SM.pch2
 Filesize:  940 Bytes
 Downloaded:  579 Time(s)
voice_alloc16_SM.pch2
Displays gates of 15 allocated voices in FX-area by DA/AD-coding on one bus (2 stages a 8 bit)
 Filename:  voice_alloc16_SM.pch2
 Filesize:  1.62 KB
 Downloaded:  551 Time(s)
Something with this universe is somehow perfectly sound and in order.
selvmarcus
G2 patch files: 39
PostPosted: Fri Mar 31, 2006 8:26 am    Post subject: Reply with quote  Mark this post and the followings unread
I post this here cause it seems to work I don´t wanna start
yet another topic now.
It gives you two note values in one signal by shifting the bits.
Note quantizer used to get integer portion of a value.
The ADCs in FX area are just used for displaying the received values.
multibyteSM.pch2
Multibyte encoding of two note values in one signal by shifting bits.
 Filename:  multibyteSM.pch2
 Filesize:  1.62 KB
