  bingsatellites Mostly Ambient
Question about Access Virus A/B/C, etc..
Page 1 of 1 [3 Posts]
lostinpurdy
PostPosted: Tue Nov 20, 2012 9:59 am    Post subject: Question about Access Virus A/B/C, etc..
Subject description: Physical Modeling Synthesis possible?
I was wondering since the access virus synths use physical modeling synthesis to simulate an analog substractive synth, is it at all possible to trick/hack/reprogram the synth to acces physical modeling parameters and, say implement an physical modeling mode (or access a hidden mode for that, if present)? In short can a synth that uses physical modeling synthesis to generate a virtual analog structure be used as an actual physical modeling synthesizer? Just some food for thought. Smile
DrJustice
PostPosted: Tue Nov 20, 2012 2:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
The Access Virus is not a Physical Modeling synth. The Virus isn't modeling anything really - it just does it's own thing. Some would class it as a Virtual Analogue though, which is natural since it uses the classic subtractive architecture.
It's not possible to access physical modeling parameters (since there are none) or implement a physical modeling mode in the Virus synthesizers - the supplied firmware represents a fixed "virtual analogue" architecture.
DJ
klangumsetzer
Audio files: 10
PostPosted: Fri Nov 23, 2012 4:26 am    Post subject: Reply with quote  Mark this post and the followings unread
hej lostinpurdy,
the yamaha vl series can make to sound like 'analog synthisizers' but the virus cannot do physical modelling like drjustice already mentioned.
(you can make it sound like a wavetable synth but it is not a wavetable synthizers.)
howard scarr's virus programming tutorial which can be found on the access music site is a good starting point to learn which sounds/timbres can be made with the virus.
best regards
eike
make a joyful noise!
Niio1
