@=> operator
Page 1 of 1 [4 Posts]
jirko
PostPosted: Sun Dec 26, 2010 4:56 am    Post subject: @=> operator Reply with quote  Mark this post and the followings unread
I have an issue with the @=> operator. I need to share the data of one array into a temporal array. So I thought that the assignment operator is the way to go, but it seems that using this assignment operator will bond the arrays. Please see the code below to see what I mean.
Code:
int A[1]; //first array
int B[1]; // second array
[50] @=> A @=> B; //assign a value to the arrays
while(1)
    Std.rand2( 0 , 16 )=>A[0]; //assign a new value only to the first array
    0.3::second=>now;
    <<<"A ", A[0] , "B ", B[0]>>>;
// we are only making new values for the first array, so
// why do we get the same values in both arrays? why is "B" not = 50?
thanks a lot!
Audio files: 218
G2 patch files: 93
PostPosted: Sun Dec 26, 2010 11:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Attaching an image descibing my take on how arrays work in ChucK. An array is a chunk of allocated memory, and the variable that you assign to point to the array is just a pointer to that chunk. Objects (instances of classes) work the same way.
There is no simple shorthand way to copy an array or an object in ChucK (much like the C-like languages it is inspired by), so you need to do something like this:
Code:
for (0 => int i; i < A.size(); i++) {
A[i] => B[i];
of course, you could just do
Code:
A[0] => B[0];
in your case, but I assume you'll want to do something more clever with the array further on.
Generally, when you're using the @=> operator, you're dealing with pointers like this, and you have to know that you're not really copying any data.
Edit: forgot to turn off html
 Filesize:  31.29 KB
 Viewed:  1745 Time(s)
jirko
PostPosted: Tue Dec 28, 2010 1:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, so this operator works like a pointer!
Very clear!
Thanks a lot Stefan for your help!
Audio files: 218
G2 patch files: 93
PostPosted: Tue Dec 28, 2010 4:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Glad when I'm able to help!
ChucK's memory handling works pretty much like the one in Java, though the requirement that you sometimes need to use @=> whith pointers adds a visible distinction from regular assignment (or copying) in the code.
Come to think of it, this is a nice effort, in the spirit of making the assignment operator => distinctively different from the equals operator ==. These things are common sources for errors in other C-like languages, and tricky to troubleshoot.
AmbiphonicDSP
